Author Subject: Great, just fcuking great!
birk
Built my new forged engine up, spent the last 4 days stripping it all down, making it all look pretty then building it back up and the twating thing is tapping its tits off Angry
Not best please, esp when im going to have to spend more time and money fixing it, and ive got to bed the engine in for 1k before mapping on the 27th Sad
Not realy sure what to do with the head, get another one reconed properly, or just reuse my head from my old engine ive just taken out.
Dan
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 6th Aug 2010 at 23:48
bobdylan_55
no bother getting it reconed, just get a known working one.
309 GTi6-T
Posted 6th Aug 2010 at 23:52
simonjames
I'd go with the 1 off the other engine that you know isnt a tapper even if its just for the running in period and mapping then when funds are a bit healthier maybe do the head with some porting
p.s not sure if the charged engines need porting
MY EBAY ITEMS
07943066306
Posted 6th Aug 2010 at 23:56
CUJ
Oh no Dan, that is seriously bad news Sad I'd do as the others suggest and use a known good cylinder head.
340 horses
Posted 7th Aug 2010 at 00:09
fletch
Track Head
Did you time it up wrong or something or is it just the lifters lacking oil?
Posted 7th Aug 2010 at 01:38
birk
I dont think ive timed it up wrong, i went over it 3 times, and it all seemed fine.
I did think it was the lifters, but after running it for a bit, it didnt get any quiter, and the noise was more promenent when the revs were increased, and its pretty loud aswell.
07889376885
Dan
Posted 7th Aug 2010 at 02:03
rwgti
SHHHHIIIITTTTT!!
Thats not good mate, gutted Sad
If you know the other heads a non tapper id fit that.Hopefully be working ok for silverstone though Smile
Team Astor Grey Supercharged GTI 6
Posted 7th Aug 2010 at 02:10
webster
I know how you feel bro...
cress87 wrote:
I'm stopped for speeding on a daily basis but now the police are aware that I live for the 306 they dare not interfere, just sit in their cars quaking as I drive past.
Posted 7th Aug 2010 at 02:21
fletch
Track Head
Did you turn the cams independently, or used a slipped pulley perhaps?
Posted 7th Aug 2010 at 03:11
birk
I turned the cams independently yea, i have a lightweight crank pulley aswell.
I did forget to time the crank pully when i put the head on, so the pistons were touching the valves when i rotated it to try and time it, but only by hand with the ratchet, so not like i was swinging on them to cause them to bend.
So to make it easier, i took the cam carriers off, let the valves all rest in place, pinnd the crank pully, then did the cams closest to time and tightend the carriers down, the inlet was in the correct place and the exhaust was about a tooth out, so moved it around, pinned it up, then started with the cambelt.
07889376885
Dan
Posted 7th Aug 2010 at 03:31
mike306
That's weird, was doing a random google seach before I saw this topic and came across
this, which seems to give a good explanation Wink Fingers crossed things will go better next time Thumbs up
High boost '6 for weekends
406 2.1 Executive for weekdays
Posted 7th Aug 2010 at 04:35
ablister
when the bottom is timed up, the pistons are in 'safe mode' ie half way up/down the cylinders therefore valves will never touch pistons if they are rotated on their own
306 rallye, Richard Longman engine
rc10gt
Posted 7th Aug 2010 at 17:15
birk
Yea, hence why they did touch when the bottem pully wasnt timed up and the head was put on when i did try to time it all up.
07889376885
Dan
Posted 7th Aug 2010 at 17:22
You need the pistons halfway down the bores Dan, and then put the head on already timed up...Yes
The fact that the valves were touching pistons is bad enough, the fact that you have turned the cams independantly tells me the valves have tangled unfortunately. I found out the hard way, many, many years ago now.....as al4x will never let me forget....LOL
Stan.
Posted 7th Aug 2010 at 23:44
like stan said;
birk wrote:
I turned the cams independently yea.
ERIC!
Doh
the valves on these engines are big enough to catch each other.
if you haven't run it for too long, and they aren't banana shaped you may get away with just a new valve not a guide as well.
Posted 7th Aug 2010 at 23:49
simonjames
quote:
fook yeah that hadn't entered my head
MY EBAY ITEMS
07943066306
Posted 7th Aug 2010 at 23:57
the inlets are bigger on the XSi too, the angle they're at and the lift they run at in the gti6 doesn't help, the xsi has a bit less lift but they'll still catch.
the stems are only 6mm.
Posted 7th Aug 2010 at 23:59
birk
I turned the cams when the head was off, i made sure they didnt touch.
Maybe they touched when i took the cam carriers off, that seems like the only way i could have messed it up, i swear i did the cambelt and timing right.
The pistons would be halfway down when the crank pully is pinned up right ? im sure i had them half way when i put the head on to start with, but clearly had it out when it wouldnt time up.
07889376885
Dan
Posted 8th Aug 2010 at 00:22
