Author Subject: clutch arm
papa
trying to drop the gearbox and removed everything except the clutch arm. Tried soaking the arm in wd40 and full force with the mole grips but will not budge. Presume only solution is the angle grider or has anyone got another answer.
Posted 6th Aug 2010 at 22:47
smegal
If you really can't get the pin out you can bend the arm up and out of the way.
Ex SC-6
Now in a Megane R26
Posted 6th Aug 2010 at 23:40
jonnie205
yes bend arm up and the attack the pin once box is out
Posted 7th Aug 2010 at 01:19
kyleey2k
i used a small drill bit to drill through the pin. Then i put i needle through the hole and used that for leverage to pull the pin out Smile
Posted 18th Oct 2010 at 07:22
