| Author | Subject: BE1 |
309btcc
**DODGY SELLER** Location: england Registered: 07 Jul 2009 Posts: 530 Status: Offline |
Anyone used this box with a gti-6 engine??? |
rallyeash
why would you want to do that? i take it you are meaning the 5 speed lift up reverse box yeah? ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
309btcc
looking for good box for acceleration and keeping some top speed a guy has that box in a gti-6 205 it still does 146mph and gets to 60 1n 5.4 secs |
tannerman
Senior User Location: POOLE Registered: 28 Apr 2010 Posts: 583 Status: Offline |
i put the box in my car for about a week.....i prefered the 6 speed...might no of one for sale if you want one________________________________________ DO YOU HAVE PROBLEMS WITH BUM FLUFF |
rallyeash
if its a standard gti6 205 with a 1.9 box i'd doubt if it will pull under 6 seconds. probably does that while hes talking about it down the pub... tbh in a 205 theres no point using 6 gears but in a 306 you may aswell stick with the 6 ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
miles
Why a BE1, BE1 and BE3 are the same ratios wise, the 1.6 (205) box will be better as the 5th gear speed is around 19.0 mph per 1000rpm so you can work that out yourself.1.9 is 20.9, but if you use the 4.4 in them then it's down to around 17mph ________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
309btcc
so iam puttin a gti-6 in a 205 ash waht box do i use its guna have fast road cams??? |
rallyeash
i'd personally use a 1.9 8v be3 box or an mi16 box.i ran a 1.6 be3 for a while, even though you get a little more acceleration i dont think its worth it, overall the 1.9 or mi box is the one to go for. These are my personal views and experiances though are you going to be running cams on the standard bottom end? if so check out the max lift @ TDC thread, that will change your mind ________________________________________ 230 hp 2.1 16v XU 205 rallye on jenveys Project thread here309 3dr K20 Type R |
1.9 box is wayyyy too long for a 16v engine.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
spiky
Seasoned Pro Location: Cardiff Registered: 13 Oct 2006 Posts: 2,310 Status: Offline |
i've run both the 1.6 (currently fitted) and a 1.9 BE1 in my 205146 is probably from a 1.9 1.9 box is not wayyyyyyy to long at all, it was fine, nice for cruising and fine on track, i took mine out as ai had a niggly fault. i'll be going back to a 1.9 soon, as i think my 1.6 will rev out too quick, with a little more power ________________________________________ Do you need a 205 > 306 gti6 plug and go engine loom? PM METORQUES for all your braided fuel line needs MY YouTube Videos' SUPERCHARGED 205 GTI6.... are you Fooking nuts!.... ummmm YIP ![]() 268+BHP and 860kg = FUN |
309btcc
hmmm maybe ill just fit the gti-6 box then and cope with the lack of turning lock... |
miles
I;ve got a 1.6 box with a 4.8, Still a top speed of 135mph, Worst case I;d use the same box with a 4.4 on anything on track, waste of time otherwise________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
