displaying posts 26 to 50 of 53
Pages (3): 1 [2] 3
Author Subject: HELP PLEASE: had my engine out now fuel pump wont prime
russbez
emm thats got me worried
that cable that comes off the negative terminal goes to the 13mm bolt (iirc) on the gearbox then to the earth point near the front of the battery (closer to the front of the car, there seems to be two earth points near each other here)
that sound right? Unsure
more and more people thinking its my earths Yes
Richw got back to me and said if the ecu was locked or anything like that - the fuel pump would still prime Yes
My Rallye project thread
Posted 2nd Aug 2010 at 16:50
spiky
so the double relay "click" when the the ignition is turned on?
if so, i would check the crank sensor
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 2nd Aug 2010 at 17:06
russbez
no they dont, only tick i get seems to be from the brake servo - which btw is that normal? usually sitting in car when i turn the key and all i usualy heard was the fuel pump priming LOL
Posted 2nd Aug 2010 at 17:07
spiky
is your inheria switch ok? maybe try bridging the wires
the 19pin plug is dirty or unplugged ?
try a know working fuel relay
MY YouTube Videos'
Posted 2nd Aug 2010 at 17:09
russbez
iv got a spare working interia swtich and double fuel relay
and i managed proved fuel pump was working
was still the same
really hoping its my earths, engine bay was sprayed, but they were covered up with tape / still had thier bolts left in
cheers for the suggestions though! Yes
and lol ....
Posted 2nd Aug 2010 at 17:23
spiky
did you click it? ...lol
MY YouTube Videos'
Posted 2nd Aug 2010 at 17:24
russbez
click what?
edit : ohh you mean press the interia switch?? ... yes many times
Posted 2nd Aug 2010 at 17:47
spiky
no, the "pic's of naked ladies" link LOL
MY YouTube Videos'
Posted 2nd Aug 2010 at 17:50
russbez
of course i did Big grin
... very nice hah
Posted 2nd Aug 2010 at 18:01
russbez
Post #35
okay all earths cleaned out
even attached a earthing kit that i had for it, put earths everywhere
still the same Sad
is there a certain time i need to press the interia switch?
Posted 3rd Aug 2010 at 02:30
russbez
Post #36
can anyone confirm this?
Posted 3rd Aug 2010 at 02:33
spiky
Post #37
Just push the inheria switch, that's it
MY YouTube Videos'
Posted 3rd Aug 2010 at 02:46
russbez
Post #38
tried it with ignition on, off on one click two clicks
does it make any noise or that?
got two switches here, two relays
i have double checked fuel pump again :s it makes a noise when i put 12v threw it Sad
Posted 3rd Aug 2010 at 03:13
gb_gti6
Post #39
sorry to hijack but the double click your on about? i have that but fuel pump primes!! should i change the crank sensor?
Team OCD
Posted 3rd Aug 2010 at 02:59
russbez
Post #40
i have no idea
fuel pump is def making a noise when i put threw 12v on it
shale i try and get a different engine loom Unsure
Posted 3rd Aug 2010 at 03:06
spiky
Post #41
you have put the perm live from battery to starter to alt?
MY YouTube Videos'
Posted 3rd Aug 2010 at 12:31
russbez
Post #42
yes
preparing a few pictures, iv got 400 odd pictures from before i stripped it all down so i know where everything went, all bolts were labelled in bags etc LOL
Posted 3rd Aug 2010 at 13:48
russbez
Post #43
incase iv got wires wrong LOL heres my earths most of them have been taped out, cleaned up with 300 odd rough wet and dry and a small bit of copper grease on them
edited : pictures removed Yes wasnt my earths
Posted 16th Aug 2010 at 16:41
spiky
Post #44
take the double relay out and put a multimetre on pin 14 and turn the ignition on
do you get 12v?
MY YouTube Videos'
Posted 3rd Aug 2010 at 14:01
russbez
Post #45
iirc, no
i will double check tonite, got an old friend who is a time served mechanic and owns a working Rallye and wants to help tonite, which is handy Smile so more relays and switches to test
also, regards crank sensor (the one with brown plug under the thermostat housing)
i have two of these, ones a few month old and the one that was on the car (working)n before i stripped it down
surely not both are faulty Sad
tried both two or three times now
pain in the ass to take them off Yes
Posted 3rd Aug 2010 at 15:54
russbez
Post #46
edit
Posted 4th Aug 2010 at 23:04
russbez
Post #47
mechanic with a Rallye turned up last night
we put my fuel pump, double fuel relay and inertia switch into his car and they all work, even had the ecu in his car, and it primed his fuel pump
we have the same voltmetre readings at the fuel pump plug on my car and his
he had a good look around trying to trace wires the could possibly be broken, we ran out of time it got quiet late
spikey, i forgot to check pin 14 specifically, he was controlling the volt metre, iirc we have 12v coming from at least one of the pins of the relay connector
mcguyver37
Post #48
Mate i havn't read all the thread but i take it you've check to see if the emergency fuel cut off switch is working ok or has not been activated by accient?
Ahh just read the ubove, yes you have. mmm strange one as the same thing happened to me but i just hit the double realy with a hammer and it kicked in.
Posted 5th Aug 2010 at 00:24
russbez
Post #49
cheers but iv tried that Smile
emm spikey, yes pin 14 has live
Posted 5th Aug 2010 at 04:18
russbez
Post #50
no one got any other ideas?
iv tested using other chassis loom and engine loom also
Posted 10th Aug 2010 at 02:37
Pages (3): 1 [2] 3
