Author Subject: Pink or Green Injectors?
mrp
So standard injectors are green but I have throttle bodies on my gti6 and the injectors are pink could anyone please tell me why???
Posted 30th Jul 2010 at 02:40
because someone fitted Pink ones Razz
Posted 30th Jul 2010 at 02:48
mrp
Yeah cheers welshpug, seriously are the colours an indication of flow rate or something?
Posted 30th Jul 2010 at 03:10
bobdylan_55
yes. but its much easier to get the code off the side and type it into google. there is hundreds of different bosch injectors, so the chance of there only being one pink injector is slim.
309 GTi6-T
Posted 30th Jul 2010 at 03:20
not directly, but you'll often hear certain sets referred to say for instance "cossie greens"
you'd have to check what the part number is on them and have a google, also check the fuel pressure.
Posted 30th Jul 2010 at 03:21
bobdylan_55
i have cossie greens Big grin
309 GTi6-T
Posted 30th Jul 2010 at 14:43
mrp
Standard ones are IW204's the pink ones I have are 0280155216 which I believe are off 2.0 16v 406's
The green injectors flow - 265 cc/min @ 3 bar
The pink injectors flow - 186 cc/min @ 3 bar
Does this mean that I wont be able to get the max potential bhp from my engine?
Posted 4th Aug 2010 at 02:52
indeed, especially on a standard ecu.
are you sure its a gti6 engine?
Posted 4th Aug 2010 at 02:54
mrp
Its not on a standard Ecu, Lumenition ECU & 45 throttle bodies polished flowed head and yes it is definately a Gti6 engine Smile
Does this mean I would be better off with gti6 injectors?
Posted 4th Aug 2010 at 03:04
as its a stock engine you're probably just about safe in their duty cycle, but if you ever want to upgrade the cams you'll need more injector and a remap for sure.
do you have a wideband lambda on it?
Posted 4th Aug 2010 at 03:16
mrp
Whats a lamba sensor look like not got one of those huh huh
Posted 5th Aug 2010 at 23:26
birk
iirc the xsi had pink injectors, and obviously that doesnt have as much bhp.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 5th Aug 2010 at 23:39
gti-dan
MRP - do you end up with much oil spraying around the engine bay with that filter on your oil breather rather than a catch tank?
Posted 6th Aug 2010 at 00:06
ballardpaul
Was thinking exactly the same. Had to move mine to under the car as it was covering the engine bay.
Nissan 350Z (300 BHP)
Posted 6th Aug 2010 at 15:14
mrp
There use to be an Xsi engine in there but I put a gti6 engine in, I guess thats why it has pink injectors?
No oil whatsoever, I have some green injectors do you think I should fit them then?
Posted 6th Aug 2010 at 20:58
ballardpaul
Cant do any harm as its a GTi 6 engine?
Posted 6th Aug 2010 at 22:08
no point, it has been mapped on those injectors, it'll just run silly rich on bigger ones without a remap.
Posted 7th Aug 2010 at 01:49
mrp
Does seem to run a bit rich now, I have all the mapping software so I could do it, any idea what sort of bhp I could gain?
Have to say I am quite happy with its performance and economy.
Posted 7th Aug 2010 at 16:51
sod all gain.
Posted 7th Aug 2010 at 19:17
