Author Subject: Cable or pedal fooked??
eugmul
Slight issue whilst driving home today, changed gear and the clutch pedal only came halfway back up. Crazy
The clutch seems ok, I can select all gears fine, just the pedal doesnt return past the bite point. If you lift it up with your foot it returns to normal hight but when pressing down there is no pressure until the bit point.
Is there a spring or something that couldve popped out to cause this?
Really frustrsting as I was on my way back from Carl's haha
Posted 27th Jul 2010 at 01:10
james_gti6
mine does this 1 out of 10 times. would be nice to find out what it is
if i dont see you in the mattress il see you in the spring
Posted 27th Jul 2010 at 01:20
berger
Does your pedalbox still have the spring for the pedal?
I'd try removing that first.
If not then new cable perhaps.
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 27th Jul 2010 at 03:28
anth
Probably the cable.
Although my pedal broke too as a result of the cable being knackered.
Posted 27th Jul 2010 at 12:39
eugmul
(Im not overly mechanically minded so bear with me Big grin ) Looking at it do you mean the spring that goes across, at the end of the white plastic bit?(In a left to right direction)If so then yes theres a spring there. Also there is a spring that sits behind the pedal, if you will, that goes from floor to fuse box direction which is attached to the pedal.
But from looking at other posts people have had a very similar probelm thats been sorted with a new cable, so a new cable is being done tomorrow, fingers crossed
Posted 27th Jul 2010 at 16:02
eugmul
How long has yours been like this??
Posted 27th Jul 2010 at 16:03
timredrallye
Its the spring attached to the pedal (but I got a bit lost in your descriptions). Mine did this and removing the spring cured it.
Also try the idiot check - if your mat has ridden up into the pedals, the same thing can happen!
Posted 28th Jul 2010 at 18:17
eugmul
New cable fitted today.Cured it so well chuffed also the pedal feels so light!
Big grin
Posted 29th Jul 2010 at 00:33
gilesy
How much were you charged? Was it just for the new cable?
Posted 29th Jul 2010 at 00:49
eugmul
Was charged £85 supplied and fitted. This was a cash price though Ninja think they wanted around the hundred mark otherwise.
Posted 29th Jul 2010 at 15:58
gilesy
f*ck my old boots, was that a gen part for that price? I need to undercut them!!
Posted 29th Jul 2010 at 21:42
eugmul
I think so the pug garage is only down the road from them.I phoned around and prices ranged from 99-140 supplied&fitted.i was happy with 85 though as ive used them before,they're works good an i wanted it done quick.
Posted 30th Jul 2010 at 00:57
