Author Subject: Removed Engine but it won't Split!!!
infosellerfsmail
Hey Guys taken out my engine on the 6 as a lump with a crane. I undid all the gearbox bolts with nothing conecting the gearbox to the engine and it won't seperate.
It has come away from the engine about 2" but will not go any further????
I have tried prying it with a bar and messing with the gears. The clutch relese lever has gone hard but i don't want to really force it so that i don't break anything??/
Hopefuly someone has had the same problem.
Be good if anyone can help
Josh
Posted 25th Jul 2010 at 03:34
birk
You have to take the clutch arm off, then it will release the clutch bearing and the box can come off.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 25th Jul 2010 at 03:43
eddy_gti6
dont forget abot the pin you need to pull out of the clutch arm or you will never get it off
Posted 25th Jul 2010 at 03:45
Sledgehammer Unsure LOL
Posted 25th Jul 2010 at 03:55
SteviePut
Take an angle grinder or plasma cutter to itThumbs up LOL
Posted 25th Jul 2010 at 04:45
eddy_gti6
Smash it!!! Whistle i have a spare gearbox for sale LOL
Posted 25th Jul 2010 at 04:47
infosellerfsmail
Cheers lads i will do that if that don't work for some reason then i'll just set fire to it!!!
Posted 25th Jul 2010 at 20:15
