ive got standard yellow ones in,
can anyone tell me what the next size up from these are?
possible where to get them from?
cheers
| Author | Subject: bigger injectors |
tarret
Regular Location: Maidstone Registered: 27 Sep 2009 Posts: 323 Status: Offline |
hi im looking at putting bigger injectors in my s16 but i dont know what ones to get,ive got standard yellow ones in, can anyone tell me what the next size up from these are? possible where to get them from? cheers |
tarret
bump |
Do you have a mappable ecu?And is the engine modified? ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
tarret
once i put the injectors in was getting it chip n remaped,only little modified |
you get it chipped, OR mapped ![]() put them in when you get that done, it wont run otherwise. p.s, S16 injectors will cope with about 180-190, so you probably don't need to upgrade them. no point getting it chipped/mapped unless you've got cams. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
tarret
ok cheers ![]() i was looking at 285 piper cams and have been told that all i need is double valve springs to put them straight in, is that true do you know? |
not sure sorry, you'd need to ask an engine builder or someone who at least knows these engines well.you could try pming Sandy brown (on here as "Sandy") or PeterT. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
tarret
ok mate no worrys,thank you will do |
