Author Subject: rear arb
xsisid
Thinking about changing my rear arb at the wkend but not sure if its as straight forward as it looks. Got the 1 out of my old beam without any probs but is there a certain way of fitting it like leaving a gap between end plate and radious arm or do he plates push right up?
Posted 22nd Jul 2010 at 03:06
0.5mm gap each side.
fit an M8 bolt in the nearside that tightens all the way up onto the plate, then when you fit the bar and pull the r/h end plate on, stick a 1mm feeler gauge between the end plate and the arm and wind it right on with a long bolt and a few washers and a nut.
Posted 22nd Jul 2010 at 03:16
xsisid
thanks, do i need any new parts for the job? so the bar should be fitted with 1 plate already fitted to it pushed right up then feed thru the beam and fit handbrake plate and bolt then just fit other plate.
Posted 22nd Jul 2010 at 03:27
yup, the nearside end plate is the one you should leave fully drawn onto the splines.
if you don't know the history of the beam you'd be best getting the 2 yellow seals and the 2 black rubber bushes for it, probably looking at about a fiver.
Posted 22nd Jul 2010 at 03:35
xsisid
nice 1. thanks Thumbs up
Posted 22nd Jul 2010 at 03:46
rob gti6
Part number for you Wink For how little they cost I would change them anyway.
P1 306 GTI6 X2
P2 306 GTI6
P3 306 GTI6
205 GTI 1.9
Peugeot Sport Club UK Gloucestershire Group Leader
Posted 22nd Jul 2010 at 04:48
xsisid
nice 1 rob thanks for that mate. are pug likely to tell me i have to buy a packet of 5 seals. iv had that before with fastenings, told me i had to buy 100 coz they were not a stock item and come in a pack off 100. i only wanted 8.Smile
Posted 23rd Jul 2010 at 00:41
