Author Subject: Fans working, but not working???
bates gti-6
My fans have stopped cutting in on my 6, I've unplugged the brown switch turned on the ignition and the fans come on. Great i thought just a new brown swith needed. Fitted that and fans still not cutting in, any ideas what else it could be?
All cars should have 6 gears!!!!
Posted 21st Jul 2010 at 23:02
bates gti-6
Also when the fan does come on when unplugged its only the drivers side that comes on fast??
Posted 21st Jul 2010 at 23:19
bates gti-6
Anyone?
Posted 22nd Jul 2010 at 00:51
anth
If only one fan comes on then it could be a relay. They are located on the cowling between the two fans.
They should come on slow speed then after a few seconds go to fast speed.
Have a search there are loads of threads on this.
Posted 22nd Jul 2010 at 01:10
bates gti-6
But isn't 1 fan for air con and the other for the rad? and the fact its working when unplugged there is nothing wrong with the fan?
Posted 22nd Jul 2010 at 01:13
306er
Mine didn’t work so i cleaned relays and bitron pins with wd40, started engine pull out brown sensor and only drivers side fan came on, smacked right side fan and it started working, must of had crap in it, put the plug back in and the fans came on as normal.
diablo 6 black 6 China Blue GTI 6
Posted 22nd Jul 2010 at 03:15
bates gti-6
When i unplug the brown plug should both fans come on?
Posted 22nd Jul 2010 at 04:02
bates gti-6
Well took the bumper off to find the wires had broke behind the passenger foglight. So i've now re-wired it and all is now fixed! Big grin
Posted 29th Jul 2010 at 16:05
bezza90
Well done. I have exactly the same problem, and Carl did say it could be wiring down there. I will take a look as soon as I get the chance now, as mine does exactly the same thing and I have changed the fans and relays for known working ones, and exactly the same thing happened.
Are the wires tricky to get to with the bumper off, or are they quite obvious?
I half checked when I had the front end off, but may well have ommitted to check that, assuming it must now be the bitron, as I had tried new fans and relays, with the same results.
Hopefully mine will be as simple as that. It did make me worry today, the single running fan (always on due to the Brown sensor being unplugged, to prevent overheating in traffic) stopped for some reason, I noticed as the temp started to go above 90 when sat in traffic, normally it sits at 80 pretty much everywhere. When I got out, I am sure the fan was not running, but when I stopped and restarted the car, it started running as normal. Shit me up a bit, but hopefully a one off. As soon as the engine was running with the fan on, temp returned to it's normal level, so the fan must have stopped previously.
'00 Astor Grey GTi-6
Team: 'EVO Triangle'
This is a quantum car. I don't know where I am, but I'm going really fast.
PS3 ID: Skaankypuppy
Normally play GT6
Posted 4th Aug 2010 at 04:58
pete26
Everything you said happen to me. Was Relay between the two fans Wink
Ph2 Black GTI6
Ph3 China GTI6
206 xsi manstone daily runner (GAY)
Ph1 Cherry Red GTI6
307 HDi 110
Posted 4th Aug 2010 at 23:18
hdk_wg
Recently my ZX S16 also the same issued.
The fans stop working except i turn on the Air-con.
The temperature when up during heavy traffic.
I also remove the brown sensor, the two fans are running, when i connect the two fan stop.
Replace the brown sensor still the same.
please help?
wg
Posted 14th Aug 2010 at 22:00
