pharse one.
jus need to know if i change the ecu do i need to change the flywheel as well. many thanks
| Author | Subject: flywheel/ecu |
umbi
Newbie Location: birmingham Registered: 14 Jul 2010 Posts: 3 Status: Offline |
hi everyone. jus brought a 306 2.0l cab n regpharse one. jus need to know if i change the ecu do i need to change the flywheel as well. many thanks |
allesclar
Seasoned Pro Location: Sheffield Registered: 17 May 2009 Posts: 4,254 Status: Offline |
what makes you think you would need to change the flywheel if you change the ecu?you been playing alot of gran turismo recently? ![]() no you dont. why are you changing the ecu anyway on a presumably standard cab. ________________________________________ Team allesclar ® |
mabgti
NV motors Location: Bham tunnel @7400rpm Registered: 28 Aug 2003 Posts: 9,127 Status: Offline |
some vag cars are flywheel dependant for cranking![]() pugs are fine ![]() ________________________________________ Team Supercharged Gti-6NV Motorsport Automotive Performance Tuning 0121 448 7515 ECU Remapping/ DPF removal VAG/BMW Diag and Option Coding Peugeot Planet ECU coding/transponder programming etc www.nvmotorsport.com Facebook Page Project S6 |
umbi
the ecu is f*cked!! on the keypad the red light and the green light comes on and still on. haven't got the code for the keypad. |
