Author Subject: Starting problem urgent help
gb_gti6
i am after some help. started fine this morning now not starting. have changed battery as wasnt the best and battery in the key fob. engine turns over but that is it? wont come to life had no problems before. Suggestions?
Team OCD
Posted 15th Jul 2010 at 23:30
james_gti6
possibly crankshaft sensor, immobilizer, ecu, check the crank sensor first, very common,
if i dont see you in the mattress il see you in the spring
Posted 15th Jul 2010 at 23:40
gb_gti6
key fob not working now either! very strange
Team OCD
Posted 15th Jul 2010 at 23:55
daveyboyholt
Are you getting any fuel through?
To do list;
Timing belt
Rad fans
Steering rack
Clutch
Rear right caliper
Posted 16th Jul 2010 at 02:19
gb_gti6
yeah i am getting fuel through
Team OCD
Posted 16th Jul 2010 at 02:21
daveyboyholt
not the immobiliser then
To do list;
Timing belt
Rad fans
Steering rack
Clutch
Rear right caliper
Posted 16th Jul 2010 at 02:44
daveyboyholt
Try doing an ECU reset as per FAQ. It might be the electrics going wibble after changing the battery
To do list;
Timing belt
Rad fans
Steering rack
Clutch
Rear right caliper
Posted 16th Jul 2010 at 02:48
gb_gti6
think might be immobiliser but not sure how to override it! need to be able to start the car to do the ecu
Team OCD
Posted 16th Jul 2010 at 03:21
If the fuel pump is priming, and you are getting fuel, it's not the immobiliser Yes
My immobiliser had a fit, and as a result it would turn over, but pump was not priming.
I would guess at a loose/dodgey earth. (Probably on the starter motor)
Posted 16th Jul 2010 at 17:20
gb_gti6
dont think its sparking and key fob not working??
Team OCD
Posted 17th Jul 2010 at 01:01
jbradders
Mine done this just turning over,fuel pump was priming but i had no spark,so changed coil pack,crank and cam sensor but still didn't work.So I got an unlocked ECU and no problems since.
Posted 17th Jul 2010 at 03:23
gb_gti6
i take it alarm doesnt work after this. did ya get thsi done or do it yourself.
Team OCD
Posted 17th Jul 2010 at 03:37
jbradders
or the immobiliser.Got the AA out when it wouldn't start he found there was no spark at coil pack and also could not connect to my car.Changed everything myself pretty easy to do.
Posted 17th Jul 2010 at 03:43
gb_gti6
this is a great help. i mean did u do the ecu yourself? i have ruled out the coil pack, cam sensor and crank sensor have tested them!
Team OCD
Posted 17th Jul 2010 at 03:51
jbradders
I brought an unlocked ecu and fitted it myself. I think someone sells them on here?
Posted 17th Jul 2010 at 04:09
gb_gti6
i think i know how to do it myself if i can find a pin diagram.do u know if there is any other way round it so it stil works?
Team OCD
Posted 17th Jul 2010 at 04:28
