Author Subject: New cambelt. Wobble?
nxa
Hi,
I have just replaced my cambelt, tensioners, waterpump and harmonic balancer.
Everything is timed up and torqued down correctly but on the first start up, I am seeing a small amount of cambelt 'wobble' on the tensioners.
I am only talking about half a mm of wobble here but since it's my first cambelt change, I'm not sure if this will settle?
Is this something to expect from a new cambelt?
cheers
Posted 13th Jul 2010 at 11:12
oldbrownshoe
wind it a little bit more .
French military victories?
Did you mean French military defeats?
Posted 14th Jul 2010 at 03:12
doesn't sound excessive at all, as long as the tension is correct and there's no discernible wobble on any of the pulleys it wont come off.
Posted 14th Jul 2010 at 03:32
nxa
Thanks once again Welshpug.
Do you think there might be any chance the slight wobble could build heat up in the belt and cause premature failure??
Should a new cambelt track 100% from the get go, or do they usually take a little running before they find their line?
Just trying to cover all angles hereLOL More for peace of mind if anything.
cheers
Posted 14th Jul 2010 at 08:10
