Just bought a 205 with a GTi-6 engine.The car is good well finished shell with good running gear 1.9 Gti box but the engine has issues.Can any of you guys help.Throttle response is flat and power is poor and uneven.The previous owner has just fitted a timing belt and I suspect it is a tooth out but when I checked visually the dowel holes don't make sense i think the damped crank pulley has spun.SO HERE IS THE QUESTION ARE THE STANDARD TIMING MARK DOWELS AT TDC IF I FIND TDC WITH A DIAL GAUGE WILL THE CAM PULLEYS LINE UP OR DOSE ANYBODY KNOW ANOTHER WAY TO ACCURATELY LINE UP THE CRANK ON ONE OF THESE ENGINES INDEPENDENT OF THE PULLEY
