im wondering, can i wire a live to the motor from the door loom via a switch? if so will it only allow motor to turn one way i.e only close?
| Author | Subject: window help |
lotek
Seasoned Pro Location: Berkshire Registered: 04 Dec 2007 Posts: 6,107 Status: Offline |
i have had enough of trying to get my windows to work now, its just not having it, its my own fault for cutting the old loom connector off instead of patching. im wondering, can i wire a live to the motor from the door loom via a switch? if so will it only allow motor to turn one way i.e only close? |
lotek
bump of despair..... |
lotek
anyone know |
sort of, you need to make the original switch get 12v in its middle pin from memory, the rocker switch shifts the earth and power wires around to move the motor up/down.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
lotek
so if i take exiting switch apart il be able to hardwire it ? |
rallyestyle
Seasoned Pro Location: London Registered: 23 Jul 2003 Posts: 14,991 Status: Offline |
COuld you just not replace the whole lot? Might work out easier if you can find most of the bits in a scrappy ![]() ________________________________________ Just Drive It |
lotek
nah its my door loom thats shagged, so its either manual or hard wire a switch in |
just fix the door loom!?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
