Author Subject: charger outlet correct?
205gti6_ro
hello all, as some of you know i'm supercharging my 205 but i've come to a slight problem with my rad and charger outlet.
i've bought a radtec shorten rad which i assumed would clear the charger outlet as other people have used the same set up but for some reason mine foul's but only just. so was wondering, is my charger outlet in the correct place?
here are some photos.
any help would be good.
thanks Ro
Posted 12th Jul 2010 at 19:11
rallyestyle
Yes it looks to be rotated to the right place Yes Smile
Is there any way of moving the rad forward a bit?
Just Drive It
Posted 12th Jul 2010 at 19:28
have you modified your rad support panel? looks like it just need to go down 10-15mm or so and it'll be fine.
(can't go forward much at all, intercooler usually sits in front of that and there's not much space in a 205!)
Posted 12th Jul 2010 at 19:32
rallyestyle
Ah ok, im guessing the IC piping will run over the top of the rad to the IC rather than down the back of the rad and then 180 into the IC. That makes sense, as you say dropping the rad down a tad will give enough space Yes
Just Drive It
Posted 12th Jul 2010 at 20:34
easypug
BAD SELLER
Is your engine mounted at the correct angle?
Posted 12th Jul 2010 at 22:11
205gti6_ro
nah i havent lowered it, wasnt sure if that was a good idea or not because i'm worried the bottom hose will be getting too close to the belt?
Posted 12th Jul 2010 at 22:29
205gti6_ro
how do you mean correct angle?
Posted 12th Jul 2010 at 22:30
easypug
BAD SELLER
Does it have a standard lower fork? (subframe to lower mount)
Posted 13th Jul 2010 at 00:14
205gti6_ro
nah i extended it about 10mm maybe less
Posted 13th Jul 2010 at 04:32
Doh
Posted 13th Jul 2010 at 04:37
205gti6_ro
other people have got away with it though???
Posted 13th Jul 2010 at 16:24
mabgti
NV motors
think the last one done with same rad was the old style charger housingYes
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 13th Jul 2010 at 21:38
