Author Subject: TPS
vernam616
Now disconnected mine which has solved the problem of car jerking and poor MPG, however am i ok leaving its disconnected -- what will be the side affects of not replacing?
Audi S3 Black Edition
Posted 11th Jul 2010 at 19:37
it'll be slow and occasionally run a bit lean.
Posted 11th Jul 2010 at 19:39
Rich E Forum Admin
Throttle response won't be as sharp and switching between open and closed loop fuelling will become unpredictable.
You can't really diagnose mixture control issues by disconnecting sensors as it has too much effect on what the ECU is doing. You may find it's not the TPS at all and even with a new sensor your problem returns.
Posted 11th Jul 2010 at 19:59
mabgti
NV motors
what rich said mate... all you have to do is get a multimeter on it... or even easier get actuator test on diagnostics and check at closed, mid, full throttleYes
A supercharged 6 wont run with one disconnected as it relies more on it for LOAD values..
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 11th Jul 2010 at 21:01
vernam616
Sad im sick of this car, i had a astor 6 previous to this and never failed on me once, ive spent well over a grand on this now getting it right
i see what your seeing about being slower, i noticed this also does smell quite strong of fuel ( it did before i disconnected it though Dunno )
Posted 12th Jul 2010 at 21:41
daveyboyholt
I know what you mean, mines a money pit. Mine revs it self at traffic lights which gets me friendly looks from my fellow commuters LOL
To do list;
Timing belt
Rad fans
Steering rack
Clutch
Rear right caliper
Posted 12th Jul 2010 at 21:49
vernam616
I had my 6 for around 1yr ½ and i changed the battery and front springs and when i bought it all it came with was MOT cert
Ive had this Rallye since the end of march and like i say spent about a grand getting it right, yet this came with a folder full of receipts... strange
Posted 12th Jul 2010 at 21:54
CUJ
Vernam I share your pain pal, these things are sent to test the patience of a saint.
340 horses
Posted 12th Jul 2010 at 21:56
vernam616
TBH i dont even want it anymore, i used to like driving my old one, going for a pointless drive just for a hoon, CBA with this, its a school runner and thats it, if i could sell it i would, but know i wont recoup the £3800 it owes me and after id lost £3500 on that bag of shit Leon FR over xmas i cant afford to lose anymore.... so im stuck with it
Posted 12th Jul 2010 at 22:03
CUJ
Look on the bright side, at least you haven't got two of the f*ckers to worry about Doh
I'm sure you will resolve the issues. It's like my last Rallye, in 3.5 years all that went wrong was a dead battery. I am feckin jinxed now though!
340 horses
Posted 12th Jul 2010 at 22:06
vernam616
Being the w*nker i am i got rid of my 6 because of "fuel economy", got myself a loan and bought a newish SEAT Leon FR TDi, after 3 months this f*cked up and lost £3500 when selling, + im back to square one, with a Rallye for shite fuel eco and stuck with repayments of the loan......... if only i had held on to itSad
Posted 12th Jul 2010 at 22:12
daveyboyholt
Have you tried an ECU reset yet? Worth a go.
To do list;
Timing belt
Rad fans
Steering rack
Clutch
Rear right caliper
Posted 13th Jul 2010 at 01:45
jimmyrallye
what happened to the seat leon mate ? engine blow up ? this is the only thing im worried about if i buy a rallye again , my old 6 wos a money pit and always breaking
Posted 13th Jul 2010 at 03:04
vernam616
Turbo oil seals gave way at 47k miles, shat the rest of the oil through the exhaust, and inturn seizing the engine, im sure the garage said it was starved and threw a conrod Dunno
either way ive have 2 bad experiences with VAG diesels, and will NEVER buy another
The Leon i bought was from a well known franchised SEAT dealer with 1 previous owner 45k miles and full SEAT dealer history at every interval on the dot
Posted 13th Jul 2010 at 23:02
vernam616
Right bit of a update, ive bought a TPS from someone on here and fitted it, and the car has stopped jerking when backing off so i presume the TPS is working ok, however ! driving to a job this morning, went to turn in and it just died on me, no coughs or splutters just cut out Sad it restarted fine and when i was backing up it cut out again, so as i got it back out onto the road (keeping the revs on ) i gave it some beans and it was fine after that
What sensor do i need to replace now Angry ?
Posted 18th Jul 2010 at 20:41
cooper666
clean your icv mines just started doing this
clio r27
ps3 id:cooperkloe
Posted 18th Jul 2010 at 21:13
vernam616
ICV been cleaned
Lambda changed
TPS changed
New battery
Full exhaust system manifold back !
Royally p*ssed off now
Posted 18th Jul 2010 at 21:23
ryangti6
Is the car holding the revs when you are steering?
If not it could be the steering sensor letting it cut out.
Ryan
Posted 18th Jul 2010 at 21:49
vernam616
Update again !
Been out to "reclean" the ICV with carb cleaner, also give the MAP a little clean, put it all back together and on idle it revs on its own up to 2.5k then back to 1k and will not stop doing it, reset the ECU and idleing has gone ok now, will have to wait and see about the cutting out issue
Posted 18th Jul 2010 at 23:07
