Will the gti6 crank sensors work with the alloy block 1.9 mi16 engine. The sensor plugs in fine but will it work? the mi16 has a metal sensor where the gti6 one is plasticcheers
| Author | Subject: mi16, gti6 crank sensors |
jonnie205
Seasoned Pro Location: Bicester Registered: 10 Apr 2005 Posts: 4,146 Status: Offline |
Will the gti6 crank sensors work with the alloy block 1.9 mi16 engine. The sensor plugs in fine but will it work? the mi16 has a metal sensor where the gti6 one is plasticcheers |
yep, they're all the same, even the later XUD's use the same sensor.the only differences you'll find are the length of the lead on them, and on the older types as you said some have a metal body. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
My V6, GTi6 and Dturbo engines all have the same ![]() ________________________________________ Nothing to see here |
