Author Subject: setting timing again
reggyboy
right this is my dilemma,locked crankshaft in place then my dad(73) who thought he was doing me a favour took off cylinder head without locking up the cramshafts to timing marks and despite looking at haynes manual cant figure out how to time the engine can anyone point me in the right direction?
Posted 5th Jul 2010 at 05:26
oldbrownshoe
There is holes in the camshafts sprockets that you
need to align with the appropriate holes in the cast.
the timing in this engines are fools proof,
just stick 6-8 mm pins through it to lock it.
French military victories?
Did you mean French military defeats?
Posted 5th Jul 2010 at 17:25
reggyboy
sprockets off inlet camshaft and sprocket has no timing hole on it
Posted 5th Jul 2010 at 13:35
oldbrownshoe
You probably missed it,
have a look at page 32
http://www.scribd.com/doc/27157040/Service-Guide-Peugeot-306-GTI-6-1997-1998
Posted 5th Jul 2010 at 17:54
joevts
timing holes aren't in the main sprocket, they are in the hub behind it, which is the bit that matters as it has a key that fits into the actual shaft. don't turn the cams independent of each other while they are still in the head as that can cause the valves to collide which will damage them easier than you think.
Posted 7th Jul 2010 at 00:12
