Author Subject: Poor MPG/Cutting Out
vernam616
Done the usual search but i was kinding of hoping someone could pinpoint it for me instead of me guessing what it could be
ive started suffering a bad MPG (20-25) compared to what i used to get when i first bought it (28-32)
ive now changed the air filter for a standard unit, new lambda, full new exhaust system including CAT and have cleaned the ICV(stepper)
its starting to p*ss me off bigtime as i was driving home tonight, dipped the clutch for the roundabout and it cut out on me, didnt "buck" or "stutter" just died Dunno
can anyone please point me in the right direction?
Dan
Audi S3 Black Edition
Posted 3rd Jul 2010 at 01:22
Not many more to choose from - CTS, MAP, TPS. I'd suggest the coolant temp over the others due to the fuel use.
Posted 3rd Jul 2010 at 01:24
vernam616
What colour is the CTS sensor and what other things would happen if thats fubared?
Posted 3rd Jul 2010 at 01:28
greeen not much more than using loads of fuel and generally running shit.
Posted 3rd Jul 2010 at 01:38
vernam616
seems like my culprit then
thanks for the help Thumbs up
Posted 3rd Jul 2010 at 01:44
vernam616
Is this what im buying !?
ECP Sensor
Posted 3rd Jul 2010 at 01:49
dunno, are you buying it? LOL
that is the ecu temperature sender yes Smile
Posted 3rd Jul 2010 at 01:51
vernam616
LOL
bit stumped now, could it be any of these others?
http://www.eurocarparts.com/ecp/k/sensor/p/Car-Parts
Posted 3rd Jul 2010 at 02:00
mabgti
NV motors
most likely TPSYes
As i bet it never cuts out if you let engine brake to 1200rpm before dipping clutch
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 8th Jul 2010 at 02:11
joevts
MAP sensor?
Posted 11th Jul 2010 at 00:35
vernam616
joevts wrote:
MAP sensor?
Looks like TPS was my culprit, i had a terrible problem of the car jerking as i backed off the accelerator and poor MPG
disconnected the TPS and it drove completly differrent Big grin
Posted 11th Jul 2010 at 14:28
joevts
isn't there a way of recalibrating the TPS? something like turn the ignition on, slowly and smoothly depress then release the accelerator, then start the car?
Posted 12th Jul 2010 at 00:32
