| Author | Subject: cylinder head |
reggyboy
Newbie Location: Neston Registered: 30 Jun 2010 Posts: 20 Status: Offline |
Does anyone know of any major problems when taking off skimming and replacing cylindr head on 306 gti 6 |
Just have a look around mate - there are quite a few potential pitfalls. You can't skim them much and you have to be very, very careful not to bend any valves or valve guides. Plenty of info on here but you'll have to look for it. Might be an article in the FAQ section as well.________________________________________ Nothing to see here |
reggyboy
Skimming head because head gasket has gone so what is max skim on these.The only thing not sure about is the injection system as iv'e not worked on these before is there any major probs with these or is it straightforward as per Haynes manual? thanks |
ablister
Senior User Location: fife Registered: 30 Oct 2005 Posts: 522 Status: Offline |
![]() H should be 137 ± 0.05 to 136.8 ± 0.05 ________________________________________ 306 rallye, Richard Longman enginerc10gt |
dr-evil
Senior User Location: Crewe Registered: 20 Oct 2006 Posts: 901 Status: Offline |
^^^ Life saver - cheers buddy ________________________________________ Cad Monkey will work for chocolate biscuits....I'm not kidding |
that picture is of the MI16/S16 head, is that 100% the correct dimension?________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
ryangti6
Seasoned Pro Location: Pontypool Registered: 01 Sep 2006 Posts: 1,839 Status: Offline |
reggyboy wrote: Does anyone know of any major problems when taking off skimming and replacing cylindr head on 306 gti 6 My main advice would be do not rotate the cams seperatly as this seems to be a very common mistake people make. Other than that its the same as any other headgasket change/skim really When pinned the cams are locked at the point where some valves are open and if you remove the pins the cams will move and the valves can hit each other(inlet/exhaust) so be very carefull. Also I dont know if you are aware that ideally you need to remove the exhaust manifold as it is very tight and you could easily hit the valves that are held open Hope this helps ________________________________________ Ryan |
