Author Subject: Cooling Fans, which part is duff?
davejay85
Sorry to start another "cooling fans not working thread" but I have searched and I think I am really close.
I have a Phase3 2.0 XSi 16v and the cooling fans have stopped working. I have replaced the brown sensor and the thermostat.
If I disconnect the brown sensor they come on and I noticed yesterday that they came on after having the aircon on for a while but they are not coming on when the engine temp gets hot.
I have checked the bitron unit under the wheelarch and it looks fine. Is there any way of testing this?
What else could it be?
It is really bugging me and I would really appreciate someone pointing me in the right direction.
Dave
Posted 29th Jun 2010 at 13:29
pete26
I had exactly the same problem recently. Found out it was a duff relay. Which is found between the two fans on the whole fan unit itself. Should be a little box, between the two fans.
Ph2 Black GTI6
Ph3 China GTI6
206 xsi manstone daily runner (GAY)
Ph1 Cherry Red GTI6
307 HDi 110
Posted 29th Jun 2010 at 14:51
davejay85
Cool I'll replace those next then. Where's the best place to buy them from?
Posted 29th Jun 2010 at 23:31
pete26
I just brought a whole second hand fan unit. Wink for 20quid . But I'm sure you can get these from pug.
Ph2 Black GTI6
Ph3 China GTI6
Ph1 Cherry Red GTI6
307 HDi 110
Posted 29th Jun 2010 at 23:42
davejay85
Update: I have now replaced the relays but the fans are still not coming on when the engine gets hot. Any other ideas?
Posted 4th Jul 2010 at 21:44
brownboy
earthing strap from battery to engine broken?? get just put a jump lead across as a earth a see if that does it thats what mine was Smile
Posted 4th Jul 2010 at 22:05
davejay85
I have just tried this but still no luck. Think its time to call an auto electrician.Sad
Posted 6th Jul 2010 at 01:03
mechanical_repairs
If you remove the brown switch plug and they work it has to be a faulty sensor??
Carl
Posted 6th Jul 2010 at 01:15
davejay85
Carl
Thats what I thought but I have replaced the brown temp tempsensor with a new one from GSF. Is there any way of testing the temp sensor?
Posted 6th Jul 2010 at 18:37
306er
just playing with mine now as my fans dont work, just unpluged brown plug and the drivers side fan runs at high speed.
diablo 6 black 6 China Blue GTI 6
Posted 6th Jul 2010 at 18:44
reggyboy
306er i have same problem did you sort it out? any ideas
Posted 16th Jul 2010 at 18:12
