| Author | Subject: Urgent* group n lower mount fitting |
tez_306
Junior User Location: Australia Registered: 16 Sep 2009 Posts: 68 Status: Offline |
My powerflex lower engine mount (the sort that comes in two halfs) has been destroyed and now i've got a group n mount i need to fit but it is on its own ie not pressed into the bracket. I need to fit this on urgently: could i use a long bolt and nuts and an assortment of plates/washers to press it in? Or is the force required too great? I tried hammering it in but it just wont go in straight. Any help appreciated |
rikky
you could do that yes, you could use some big flat sheets and wind it in using enough force. did a rear trailing arm bush on an audi this way but a press is much better. i have totally solid mounts and had to get about 5tho skimmed off my mount to be able to press it in ![]() don't hammer it, it won't go in straight ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
tez_306
Will try it tomorrow, in the mean-time...![]() so f*cking ghetto |
whip the bracket off and visit a local garage, seeing as the old one is already out they might just fit the new one for a few beer tokens ![]() and people wonder why I say the powerflex ones are a bit naff ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
mabgti
NV motors Location: Bham tunnel @7400rpm Registered: 28 Aug 2003 Posts: 9,127 Status: Offline |
dont use any lube apart from a bit of diesel around it before you press it![]() ________________________________________ Team Supercharged Gti-6NV Motorsport Automotive Performance Tuning 0121 448 7515 ECU Remapping/ DPF removal VAG/BMW Diag and Option Coding Peugeot Planet ECU coding/transponder programming etc www.nvmotorsport.com Facebook Page Project S6 |
cwspellowe
Seasoned Pro Location: Calderbank Registered: 19 Jul 2009 Posts: 6,496 Status: Offline |
I deep froze my bush and acetylene torched the mount, gave enough slack to tap it in.________________________________________ Bye bye Sundance Kid |
lwgti-6
Senior User Location: Nottinghamshire Registered: 27 Oct 2008 Posts: 906 Status: Offline |
I needed a 10 tonne press to push mine into place...________________________________________ EX Bianca 6 owner,Now drives: Octavia vRS |
so did I, but it only took 2 to get it in ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
chrisd306
Seasoned Pro Location: Perth Scotland Registered: 26 Nov 2005 Posts: 10,061 Status: Offline |
i done mine wit.... oh wait a min i bought mine already pressed in from Carl lol________________________________________ In my garage just now2003 BMW M3 & 2009 L200 Raging Bull & Audi Q5 S Line AX stock rod & Saxo Stock rod Sold the bike an charged rallye an bought a caravan, midlife crisis or what! |
tez_306
Lol what a f*cking head f*ck..Never have i felt vibration as severe as this.. Wood is NOT an ideal material for engine mounts. I don't know how those hardcore mother f*ckers out there cope with solid mounts in their track cars. Intense bros... Anyway, I tried installing the group N mount I had lying around. ![]() (Timber type R mount on the left, Group N mount on the right) But it turned out to be impossible without taking the bracket out and using a bench press. I tried bunging up a clamp using a big bolt/nut and old bearings as washers/spacers but it just wouldn't go in straight and I need this car to get to work tomorrow. After about 10 attempts and a stiff neck - I ended up doing this. ![]() Rubber sheets cut into a long strip and wound onto the shaft from the powerflex mount. haha this is probably the best thing i've ever made in my life. |
rikky
you crazy german, get the mount whipped off, it's only 3 bolts (plus shaft locking pins) seriously, you could have had it off and down at a garage to press in by now ![]() solid ones = interesting ![]() ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
rikky
"timber type r mount" ![]() ________________________________________ 306 rallye reproduction decals (full sets/individual decals) | 306 b-pillar textured vinyl weatherstrips306 slam panel esso stickers | 306 yellow / orange / pension fund red side door badges gti6 inlet manifold badges | 306 rear boot badges (p2/p3) winner of Extraction of toys from prams with outstanding vigour award 2009 [source: gti6 owners club] |
tez_306
As if. I'm pretty sure that the driveshafts need to come out and shit to get that bracket out. Or am i just the dumbest.. |
rikky wrote: you crazy german, get the mount whipped off, it's only 3 bolts (plus shaft locking pins) seriously, you could have had it off and down at a garage to press in by now ![]() solid ones = interesting ![]() its 4 bolts Rikky, 16mm heads ![]() agreed though, I don't get why people bother trying to do these on the car! yes the driveshaft has to come out, its not that hard though, 35mm hub nut and one BJ pinch bolt, bucket to catch the gear oil, done in 20 minutes last week. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
tez_306
That would not be beneficial to me cause i dont have a bench press and its 8pm in australia right now annndd i have work tomorrow |
mike306
Senior User Location: Lancs Registered: 11 Jun 2005 Posts: 532 Status: Offline |
some innovative fixes there________________________________________ High boost '6 for weekends406 2.1 Executive for weekdays |
oldbrownshoe
Seasoned Pro Location: Holon Israel Registered: 08 Aug 2008 Posts: 1,795 Status: Offline |
missed this ?http://www.306gti6.com/forum/showthread.php?id=123640&page=1 ________________________________________ French military victories?Did you mean French military defeats? |
tez_306
yeh dude, i tried that. Wasn't working for me - although i didn't have spacers as nice as you did. |
