Author Subject: can a gti6 engine become a tapper without the belt snapping?
j205
Hi all, I was driving my sc'd 6 engined 205 a few weeks ago. The engine has always been quiet with no tapping, until that day anyway.
The tapping started after I had taken her for a spirited run, I could hear the tapping over my music so knew it was bad. I've changed the oil and checked the timing and all is well, but the tap still remains
Does this sound like i've got a bent valve/ guide?
Posted 23rd Jun 2010 at 03:19
chris with a pug
That sounds like a bottom end bearing gone.
Posted 23rd Jun 2010 at 03:50
j205
oh god don't say that, I put a long screw driver on the engine to pin point the noise and its deff coming from the top
Posted 23rd Jun 2010 at 04:08
mechanical_repairs
Remove the oil filler cap and see if you have any oil spraying around, i have had a few where the oil filter breaks up and clogs the one way valve in the head restricting oil flow, that sounds like its very low with oil to the top end.
Carl
Posted 23rd Jun 2010 at 13:01
Also check that all the spark plugs are tight as if they come loose they can make a sound like the engine is tapping...Yes
Stan.
Posted 23rd Jun 2010 at 13:05
conrad2009
sounds like the heads as dry as the sahara Sad could you not flush the oil out and try some fresh oil incase the oilway is blocked??
Posted 24th Jun 2010 at 00:01
j205
I went over to check the oil today,(its at my parents house) and managed to forget to see if there's any oil in the head, D'oh. When she started up she was quiet with no tapping
I left her ticking over and eventually the tapping came back to sound the same as the first video.
If there isn't enough oil getting to the head is it a head off to sort it?
Posted 24th Jun 2010 at 02:44
dented_vts
Carl
I presume no oil spraying around = very bad?
Posted 24th Jun 2010 at 03:11
allesclar
what oil you using?
Team allesclar ®
Posted 24th Jun 2010 at 03:13
j205
I'm using Silkolene PRO S 10-50w, not the best but the best I could afford
Posted 24th Jun 2010 at 03:18
rich_w
It's hard to tell if it's top or bottom end from the vid.
It could be bottom end, even if the noise is coming from the top. What happens is when the big-end spins, the bearing gets chewed up creating play on the crank. This causes the piston to get thrown up the bore further than it should, kisses the valves, and results in tapping.
As it doesn't do it from cold I would be more inclined to say bottom end - big ends don't always knock when the oil is cold and viscous.
I would drop the oil and see if there's any swarf in it.
If it was a head oil supply issue, it would do it from cold. I doubt it is this.
The other option is the timing belt has jumped a tooth, but I think this is unlikely if it sounded normal from cold.
I hope this helps mate, give us a call if need be Smile
Contact Details:
07732 822546
Posted 24th Jun 2010 at 04:05
spiky
It's scrap
i'll give you 1500 for the kit LOL Big grin
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 24th Jun 2010 at 14:56
j205
Thats really bad news Sad Think itll be staying off the road for some time.
Posted 25th Jun 2010 at 00:35
davedgti6
Did you check the spark plugs are all tight? Not the end of the world though if your engine is fooked, plenty of good ones come up for sale
Posted 25th Jun 2010 at 01:27
j205
Yes the plugs are tight, I had them in and out to do the compression test.
I'm not too sure on the bottom end problem though, the oil pressure is good on the gauge the noise is more tappy than knocky. I'll have to get the sump off to investigate more when I can be bothered
Posted 26th Jun 2010 at 06:24
