Author Subject: 309 VTS
joevts
i have a couple of xsara engines: a mostly intact 1.8, and a VTS lump that has shat a rod. my plan is to rebuild the VTS head, stick it on the 1.8 bottom end and run it on carbs in my 309.
now i'm coming to the point where i need to start building the engine so being the novice that i am i could do with some words of experience.
firstly, won't a smaller swept volume with the same sized combustion chamber give a lower compression ratio?
secondly, do the XU7 pistons have cutouts or will they need machining to allow clearance for the bigger valves (also bearing in mind the head has been skimmed)?
thirdly, what head gasket will i need? are they pretty much the same apart from cylinder bore? and i assume i'll need a thicker one with the skimmed head?
fourthly, before i start taking the XU7 to bits, it has been stood a while with no inlet manifold and the ports unprotected so theres probably crap in the bores, would it be a good idea to just take the head off and give the bores and piston top a wipe down with a lightly oiled rag to pick up the crap? i also heard from someone that turning the crank while the head is off would disturb the liners and i'd need new liner seals, this puts me in a predicament if the engine isn't at TDC already as it would mean turning the crank while there is an unknown quantity of crud stuck to the cylinder walls. any suggestions?
fifthly, on the subject of carbs, i've been looking at twin 40s but then today i heard someone say they aren't big enough for a GTI6, is there any truth in this?
and if anyone has any other random advice feel free to throw it at me Smile
Posted 23rd Jun 2010 at 00:05
vts_tibi
4th.: do not turn over the engine until you removed the dirt from the combustion chamber as it could make a few scratches on the cylinder wall - clean it out properly, oil up the walls and turn it over after
5th.: a GTI6 would need DCOE45s
VTS
best 60' : 2.272
Team Trackday™
Posted 23rd Jun 2010 at 01:51
snillet
The XU7 is 16V?, if not the whole job becomes a bit more tricky.
Member of Peugeot Sport Club Sweden
http://www.peugeot-sport-club.com/
My son: http://www.youtube.com/watch?v=jzjSBKkMHDA
Posted 23rd Jun 2010 at 01:59
vts_tibi
it is
VTS
best 60' : 2.272
Team Trackday™
Posted 23rd Jun 2010 at 02:30
joevts
when you say it would need 45s, you mean trying to run it on 40s would be utterly pointless?
and so what about the liner seals? does this mean i have to take off the head, clean out the bores, then put the head back on so i can turn the crank to the right position?
Posted 23rd Jun 2010 at 04:35
ryangti6
You can do one of two things really,
1: When you remove the head clamp the liners, you can buy a tool to do this or you can use big washers and suitable bolts in the head bolt holes
2: Change the liner seals so it doesnt matter if they move
Ryan
Posted 23rd Jun 2010 at 05:06
jonnie205
changing liner seals is a huge job, requires a total engine stripdown.. i would just fit the engine as it is, spin it over on the starter to get oil pressure then run it
Posted 23rd Jun 2010 at 16:06
vts_tibi
Blink
it has a few inlet ports open, and it's been sitting in a shed somewhere for over months
VTS
best 60' : 2.272
Team Trackday™
Posted 23rd Jun 2010 at 17:19
joevts
vts_tibi wrote:
Blink
true LOL i think the men in white coats are on their way to tie jonnie up before he gets his hands on any more XUs LOL
Posted 23rd Jun 2010 at 23:55
joevts
so the liners sit flush with the top of the block and all i have to do is make sure they don't come up? think i'll get the head off then set about finding/making some big washers. haven't been up to the garage where the engine is for a while, so there's a slight chance it could be at TDC anyway from last time i tinkered with it.
Posted 23rd Jun 2010 at 23:58
