cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD
Black p3
| Author | Subject: Braided hoses |
swiftyboi006
What are the benefits of braided hoses? And is it a bit deal to fit them or is it a garage job?________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
vincemasi
Newbie Location: hitchin Registered: 03 Mar 2010 Posts: 24 Status: Offline |
the only benefit i can think of is that they last longer than rubber ones as they do not tend to crack as easily and they look nice .when i had them on my car i did not notice any change in braking performance. as for the fitting its quiet easy 15 min per side only a spanner. And dont forget to bleed the brakes after your done!! |
swiftyboi006
Look nice? Can you actualy see them lol?________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
mr swampy s16
**BAD SELLER** Location: out and about Registered: 22 Oct 2003 Posts: 10,550 Status: Offline |
as said last longer better pedal feel better braking effect due to less expansion of the hose plenty of detail on the net about them |
swiftyboi006
Jus another thing im getting some mintex discs wiv pads but what pads do i need it says i need to choose between lucas pads with a spring at the top or bosch pads?????________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
mr swampy s16
swiftyboi006 wrote: the correct ones for the caliper Jus another thing im getting some mintex discs wiv pads but what pads do i need it says i need to choose between lucas pads with a spring at the top or bosch pads????? |
swiftyboi006
Standard calipers on a ph1 6?________________________________________ cherry p1.....SOLD (regreting this)blaze p2.....why did i buy this SOLD Black p3 |
bobdylan_55
Seasoned Pro Location: derby Registered: 28 Mar 2009 Posts: 1,466 Status: Offline |
the main advantage is that they dont expand as much when under pressure, which means no spungy pedal. ________________________________________ 309 GTi6-T |
anth
swiftyboi006 wrote: Standard calipers on a ph1 6? Probably Lucas, it will actually be stamped on the caliper |
