Author Subject: cam pulleys
nxa
Hi,
I am advancing my inlet cam on the s16 and had a few questions I was hoping someone could answer.
Would a drill bit be strong enough to lock the cam pulley while I loosen the centre bolt?
How do I lock the inlet cam pulley (once it is advanced (timing holes won't be aligned)) to tighten the centre bolt back up?
Thankyou
Posted 18th Jun 2010 at 15:58
ablister
yeah, a drill bit will be fine (may be tricky getting in the available space?) although the torque setting isn't as tight as you'd think and advise using a little loctite.
Is the cam pulley not adjustable type like on gti6's where the pulley and timing hole don't move but the cam itself does?
306 rallye, Richard Longman engine
rc10gt
Posted 19th Jun 2010 at 17:22
nxa
Thanks for your help ablister,
I am not sure on the S16 setup but I am hoping it's the same as the gti6.
cheers
Posted 20th Jun 2010 at 08:38
noooo! never use the locking pin to hold it whilst you loosen the bolt!
S16 with the RFY engine does not have adjustable cam pulleys btw.
Posted 23rd Jun 2010 at 04:26
nxa
Can you please suggest something else I could use?
It's my first time in the 306 cambelt area, so any advice would be appreciated.
Posted 23rd Jun 2010 at 05:35
pgti6
Whip the cam cover off & put a spanner on the hex cast into the cam/s (22mm I think it is).
Mucho safer than the locating pins.
N5 XU10J4RS Road car
D60 XU9J4 Track car 120Kw atw
Posted 23rd Jun 2010 at 07:11
nxa
Thanks guys, got the pulley bolt out without too much trouble. Now I can't get the cam pulley offLOL
Is there a way to get these off without using a puller?
cheers
Posted 5th Jul 2010 at 13:25
nxa
*repost
Posted 5th Jul 2010 at 13:31
