Peugeot 306 s16 '97---
| Author | Subject: 405 T16 front calipers on S16 |
vandal.pr!
Junior User Location: Zadar, Croatia Registered: 18 May 2008 Posts: 63 Status: Offline |
Will this fit to a S16?________________________________________ Peugeot 306 s16 '97--- |
no, sorry!________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
vandal.pr!
ok, thanks, searching for gti6 calipers again...________________________________________ Peugeot 306 s16 '97--- |
Carl Chambers
Seasoned Pro Location: suffolk/norfolk Registered: 10 Sep 2004 Posts: 2,897 Status: Offline |
welshpug! wrote: no, sorry! Do you know that for sure? 405 Mi 16 brakes 4x4 are the same as 306 S16s, so why would the T16 not fit? ________________________________________ Carl Chambersemail; pugnacious.peugeot@yahoo.co.uk . C.M.CHAMBERS CARS Peugeot Specialist Tel; 01379 586101 after 6.30 or 07889 082466 anytime. pugsport-racing.co.uk |
alastairmoore
Junior User Location: Carlow Registered: 14 May 2008 Posts: 73 Status: Offline |
T16's have 283mm discs all other 405's have 266mm.________________________________________ 00 306 GTi 6 48,000 miles92 205 GTi 1.9 88,000 Miles 91 205 GTi 1.6 28,000 Miles 94 405 Le Mans 75,000 Miles 95 306 Roland Garros Cabrio |
miles
405's use 406 hub fitment and hence why Brembo 4 pot's & 305mm disc's fit a 405 and not a 306.I thought the 405 and S16 Yoke's where different thou ________________________________________ 306 Rallye Sptint/Race Car, 205 CTI 1.9 8v to name a fewRoad, Track and Race/Rally car preparation to your personal requirements, Full Workshop & Diagnostic Facilities New and Second parts, from Plugs to Turbo's We now also carry out Routine Servicing www.pugracing.com & FB Page, https://www.facebook.com/PugRacing Ebay; http://stores.ebay.co.uk/Pug-Racing-Shop 2012/2013/2014/2019 Class Winners at Gurston Down Speed Hillclimb & Joint overall, Class record too along the way, |
what Miles said re- the hubs.the S16 and 405 M16's caliper body itself may be identical, but the yoke and discs are very different, meaning they don't fit. obviously being the same hubs on the T16 as any other 405/406 T16 brakes wont fit to a 306. Carl, I guess you haven't yet tried fitting your Xantia/C5 discs and 406 brembos from Adam to your 406 estate found that you WILL need to buy 406 V6 Coupe Discs because the C5/Xantia 288mm discs are the wrong diameter and offset.... ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
Carl Chambers
welshpug! wrote: what Miles said re- the hubs. the S16 and 405 M16's caliper body itself may be identical, but the yoke and discs are very different, meaning they don't fit. obviously being the same hubs on the T16 as any other 405/406 T16 brakes wont fit to a 306. Carl, I guess you haven't yet tried fitting your Xantia/C5 discs and 406 brembos from Adam to your 406 estate found that you WILL need to buy 406 V6 Coupe Discs because the C5/Xantia 288mm discs are the wrong diameter and offset.... looking in my Apec brakes book 306 S16 uses pad872 lucas pad814 teves pad915 abs pad1107 bosch dsk519 266mm 405 Mi16 2wd and 4wd uses pad872 lucas pad546 lucas dsk519 266mm and I have just used 405 Mi16 discs and pads on a 306 hence why I asked as for the 406 brembos bought off adam b I had someone who maybe wanted the xantia discs hence why I had them, but Im sure I can make them fit edit; the lucas trw book lists S16 brakes the same as MI16 aswell! ________________________________________ Carl Chambersemail; pugnacious.peugeot@yahoo.co.uk . C.M.CHAMBERS CARS Peugeot Specialist Tel; 01379 586101 after 6.30 or 07889 082466 anytime. pugsport-racing.co.uk |
Carl Chambers
oh and guess what, it lists the 405 T16 discs as the same disc as the 306 GTi-6 ones in the TRW book!!! disc DF1123 283mm pad GDB1259 for the GTi-6 pad GDB1051 for the T16 So vandal.pr! yes they will fit no problem! ________________________________________ Carl Chambersemail; pugnacious.peugeot@yahoo.co.uk . C.M.CHAMBERS CARS Peugeot Specialist Tel; 01379 586101 after 6.30 or 07889 082466 anytime. pugsport-racing.co.uk |
