Author Subject: cam and ignition timing help
bobdylan_55
hi.
just trying to set my megasquirt up for my gti6 turbo, cant even get the b*tch to start though.
It managed to start and run for about 5 seconds the other day on a 1.6 xsi map (106) but ive since changed it and now it wont even turn over. i cant see how a 1.6 non turbo map would even be close to a 2.0 turbo map...
anyway
does anybody know what ignition settings i should be using. im looking for
trigger angle
teeth on wheel and missing (i presume this is 60-2?)
also any spark tables etc would be helpful.
cheers
309 GTi6-T
Posted 16th Jun 2010 at 01:15
gti6neil
put the 1.6 map back in and just get it down to some one who can set it up on a rolling road getting a turbo map wrong can be exspensive. would recomend that you retard the timming from 2500 rpm upward and increase the injector opening times by about 15% and then just run it very gently if you have to.Happy
yeah the zx td is back on the road front mounted intercooler fitted fuel pump tweaks now required + turbo adjustment
Posted 16th Jun 2010 at 01:25
bobdylan_55
the 1.6 map didnt run for more than 5 seconds and i know its running extremely lean which i definately do not want.
309 GTi6-T
Posted 16th Jun 2010 at 01:27
smighall
Smeg-all
Drop me a pm with your email and i'll send you all my MS files that i got my gti6 lump on bodies running with (although very badly). I remember it took ages to get it to pick up the cranking right.
It was 2 years ago and i've got loads of different files so easiest to just zip it all and email you.
Meh
Posted 16th Jun 2010 at 01:31
smighall
Smeg-all
Meh
Posted 16th Jun 2010 at 01:35
bobdylan_55
ta mate, ill have a look compared with mine when i get chance. I have to run it on my laptop as desktop doesnt have correct port to connect to me ms.
309 GTi6-T
Posted 16th Jun 2010 at 01:36
