Author Subject: best tool/method 4 removing ball joints
dented_vts
I want to change one ball joint when I swap in my new dampers, but I'm anxious how i will get the old one out- its been in there 12 years. Also is there a risk of damaging the hub? I will be using all new fixings and tightening them all with a torque wrench to the recommended figures.
Posted 10th Jun 2010 at 20:18
spanner/socket+ratchet will do the job Thumbs up
Posted 10th Jun 2010 at 21:40
cress87
I use one of these to remove stubborn ball joints. You are unlikely to damage the hub but it will probably split the rubber boot on the joint. Obviously that's not an issue if you are fitting a new one. Thumbs up
Posted 10th Jun 2010 at 21:45
And probably a BFOH.... Wink
Posted 10th Jun 2010 at 22:19
black 6
+1 for a BFOH and goggles In case the splitter goes flying!!LOL
Although it's no longer available new, it's worth trying to get hold of a good example second-hand. As GTi's get tubbier and cooler, it's nice to remind yourself of why insurance companies hate hot-hatches so much.-Top Gear on the 6 Apr '01. Black 6
Posted 10th Jun 2010 at 22:51
anth
balljoint folk and a very heavy hammer will do the job.
Posted 10th Jun 2010 at 22:53
smegal
I knock a chisel into the pinch part when the bolt is out. A swift twat to the wishbone with a rubber hammer and the job is done. I've read somewhere you shouldn't do this but oh well it's always worked for me.
Ex SC-6
Now in a Megane R26
Posted 10th Jun 2010 at 22:58
indeed, you should never do that, it leads to stretched balljoint clamps bent balljoint clamp bolts and inevitable shite handling Thumbs up
worst case scenario is the BJ becomes detached from the bottom of the hub carrier due to the clamp cracking, I have seen this happen, it funked that corner of the car pretty much.
Posted 10th Jun 2010 at 23:03
dented_vts
So is it ok to bash it with one of those spade things?
Posted 10th Jun 2010 at 23:20
get the tool cress quoted above, i use mine all the time, its indestructible and also useful for throwing at dogs shitting outside your driveway
Posted 11th Jun 2010 at 00:19
dented_vts
is that it:
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_216891_langId_-1_categoryId_165469
Posted 11th Jun 2010 at 00:26
anth
dented_vts wrote:
is that it:
Yes thats the one i have
Posted 11th Jun 2010 at 01:04
smegal
I highly doubt that that can actually happen unless you are really ham fisted. Surely it flexes like the part that holds the strut? It has never caused me any issues.
Ex SC-6
Now in a Megane R26
Posted 11th Jun 2010 at 01:51
it can happen, I have seen it LOL
the strut clamp is fr more substantial
Posted 11th Jun 2010 at 01:57
