displaying posts 1 to 25 of 46
Author Subject: Low comp GTI6
spiky
ok
using std engine, are there readily availble low comp pistons that i can put on GTI6 rods?
or will i need new rods too?
looking to get 8:1 ration for turbo conversion.Ninja
MY YouTube Videos'
268+BHP and 860kg = FUN
Posted 9th Jun 2010 at 19:26
bobdylan_55
changing rods can be a pain in arse so would be easier to find some pistons that have the right size rod straight away. as said, xu10j2te pistons have a big dish to lower the compression and use same length (iirc) con rods. These give 8:1 iirc.
309 GTi6-T
Posted 9th Jun 2010 at 19:44
spiky
so s16 pistons and rod? will 8:1 ? seems to easy?
not using a decomp plate?
MY YouTube Videos'
Posted 9th Jun 2010 at 19:47
bobdylan_55
no not s16 pistons, 2.0 8v turbo from a 406.
it is easy, the hard bit is fabricating a turbo onto it...
although you might want to find out if the 16v heads valves will clear the turbo pistons as they have no valve cut outs. im not sure if it will or not, never tried it
309 GTi6-T
Posted 9th Jun 2010 at 19:54
rallyestyle
Might as well go custom rods and pistons so you can safely crank up the boost Devil
Just Drive It
Posted 9th Jun 2010 at 20:15
bobdylan_55
depends on budget though mate. custom rods and pistons are £900+ in some cases. where as my s16 and a decompression plate cost me £200 total. If your planning on running more than 20psi boost its probably worth it though.
309 GTi6-T
Posted 9th Jun 2010 at 21:45
rallyestyle
Trur true. I would just think the temptation to up the boost would be too high Doh
Just Drive It
Posted 9th Jun 2010 at 21:55
jarrus464
wossner do some 8:1 pistons for the gti6, probably the best way to go i reckon, and from what I can find, (using rich w as an example) then they will fit on the gti6 rods
Posted 9th Jun 2010 at 23:34
spiky
i will want up to around 20-22 eventually, as above, you always want more....lol but i have to be realistic and that its fwd and traction will be an issue
if there is a cheap (cheaper than 1k for low comp) option then i would do it at the same time, rather then run high comp, then later to low comp and then have to buy a new turbo and mapping again
MY YouTube Videos'
Posted 9th Jun 2010 at 23:36
bobdylan_55
for under a grand you could get rods and pistons forged in low comp version... but this wouldnt include the cost for the remainder of the conversion.
309 GTi6-T
Posted 9th Jun 2010 at 23:39
allanallen
Just to add there are 2 different types of 8v turbo pistons. One is dished and the other is a flat top iirc.
I think the low compression on the 8v's is achieved by large bowls in the head rather than the pistons. There was a fairly good topic on drivers about it a while back.
I'm interested in the c.r of a standard rs engine fitted with s16 pistons though if anyone knows?
Facebook
Posted 9th Jun 2010 at 23:42
matt h 306
Turbo now is it?
Is that to keep the noise down or for POWER.
Posted 10th Jun 2010 at 00:18
spiky
sc or turbo, both same noise wise, give or take,
to get SC i need over 2k close to 3k for second hand
and thats 240bhp
i'm hoping to sell ITBs and inject more funds up to around 2k'ish (total), and i'd hope to get around 300-350 Big grin
just the Low comp and Ex manifold are the parts that are causing me a headache (costs)
MY YouTube Videos'
Posted 10th Jun 2010 at 00:22
peder_306
take the XU10J2 pistons and take of like 2mm.
Samething for mi16, take the pistons from xu9jaz ( 205 gti ) and take of 2mm on the piston.
Peugeot 306 Dimma CoupƩ.
sosmotorsport
flat top piston 8v turbo bottom end & gti-6 head
100% works
SOS Motorsport
www.sosmotorsport.co.uk
450bhp 205 16v Turbo
www.facebook.com/pages/SOS-Motorsport/159917677353556
Posted 10th Jun 2010 at 00:25
gti-dan
is it not difficult fitting forged pistons to standard pins - something about a floating pin or something?
Posted 10th Jun 2010 at 00:28
spiky
100% works
what year 8v turbo?
and mods needed to bottom end then?
any idea on CR with these two mated?
glad you posted, was going to grab you on msn and have a chat Big grin
MY YouTube Videos'
Posted 10th Jun 2010 at 00:32
matt h 306
and thats 240bhp
Is that still on the Dta?
Sounds like a good plan, 350bhp would be mental in your 205.
Posted 10th Jun 2010 at 00:49
allanallen
Any ideas on the compression ratios this would give you and do the pistons still need pocketing for valve clearance?
Facebook
Posted 10th Jun 2010 at 00:51
sosmotorsport
100% works
what year 8v turbo?
LOL an early turbo engine like a xm etc
the head bolts straight on
would atleast use new rings , bearings water & oil pumps tho
and arp bottom end rod bolts
other than that away you go
cr should be around your 8-1 Smile
SOS Motorsport
Posted 10th Jun 2010 at 00:55
peder_306
It will be around 8ish, not sure of the numbers but it will hold as long as you got the proper mixture.
No need for pocketing Smile
Posted 10th Jun 2010 at 00:57
spiky
this seems like a nice cheaper option
and readily avaible Big grin
do you know which yeah car i need to get an engine from?
MY YouTube Videos'
Posted 10th Jun 2010 at 01:05
spiky
100% works
what year 8v turbo?
cheers dude, great info
also thanks to evryone for the info, keep it coming Big grin
next on the list is the ex manifold Smile
other than the DP one?
MY YouTube Videos'
Posted 10th Jun 2010 at 01:07
peder_306
405/605/306/(406 122hp
Posted 10th Jun 2010 at 01:21
spiky
plenty of chioce then
MY YouTube Videos'
Posted 10th Jun 2010 at 01:25
