| Author | Subject: running temperatures |
bluesixxer
Newbie Location: Worksop Registered: 08 Jun 2010 Posts: 9 Status: Offline |
an easy one for everybody... recently acquired the car and was wondering if the temperatures it runs at are right, i believe the car has been stood a while altho it has a new radiator, fitted up on perchase... the range of water temps it runs at vary from 75c - motorway - all the way upto 95c in traffic (the traffic cleared at this point)... this seems quite a big range to me... oil sat at 90c, never moved... will fit a new thermastat regardless... one other thing, what temp shold i expect the fans to come in at?? any feedback much appreciated... watto |
pugjim
Seasoned Pro Location: Sheffield Registered: 11 Mar 2007 Posts: 1,380 Status: Offline |
bluesixxer wrote: an easy one for everybody... recently acquired the car and was wondering if the temperatures it runs at are right, i believe the car has been stood a while altho it has a new radiator, fitted up on perchase... the range of water temps it runs at vary from 75c - motorway - all the way upto 95c in traffic (the traffic cleared at this point)... this seems quite a big range to me... oil sat at 90c, never moved... will fit a new thermastat regardless... one other thing, what temp shold i expect the fans to come in at?? any feedback much appreciated... watto Sounds about right to me. |
james_gti6
Senior User Location: Goodwick Registered: 18 Jan 2010 Posts: 528 Status: Offline |
I had the same question when I bought mine, mine runs in the same bracket as yours, my fan comes on just under 100, ________________________________________ if i dont see you in the mattress il see you in the spring |
psjunkie
Seasoned Pro Location: Halifax Registered: 31 Aug 2007 Posts: 1,565 Status: Offline |
yep my last 2 6's have run at this and have always been alright ________________________________________ 1997 P1 Gti 6 Charged |
kit
Seasoned Pro Location: Location: Location: Registered: 22 Jan 2009 Posts: 2,394 Status: Offline |
It's what these cars usually run at. No need to change thermo. Fans will kick in around 100. Oil temp won't go above 90 unless there is a problem or you're giving it stick on a track.Changing the rad for a Nissens alloy unit will slightly reduce the running temp (although, not by much) and they won't corrode, unlike the rubbish rads Pug produced ________________________________________ Racing driver, fighter pilot, astronaut, compulsive liar. |
ghost6
Newbie Location: grantham Registered: 18 May 2010 Posts: 46 Status: Offline |
i was just reading through and my oil temp keeps going over 90 and sitting at more like hundred would this be the thermostat?________________________________________ ghost |
lee_gti6
Seasoned Pro Location: Kent Registered: 29 Jan 2005 Posts: 1,147 Status: Offline |
ghost6 wrote: i was just reading through and my oil temp keeps going over 90 and sitting at more like hundred would this be the thermostat? How old is the oil? ________________________________________ Proud member of the Astor owners clubTeam Charged Swirl pot and silly boost kit for sale |
Rich E
bluesixxer wrote: an easy one for everybody... recently acquired the car and was wondering if the temperatures it runs at are right, i believe the car has been stood a while altho it has a new radiator, fitted up on perchase... the range of water temps it runs at vary from 75c - motorway - all the way upto 95c in traffic (the traffic cleared at this point)... this seems quite a big range to me... oil sat at 90c, never moved... will fit a new thermastat regardless... one other thing, what temp shold i expect the fans to come in at?? any feedback much appreciated... watto 75 is too low. Our cars use an 83 degree thermostat so once warmed up the temperature shouldn't be below 80 really. I suspect you have a leaking thermostat, most likely due to the seal rotting. edit: The upper ranges of the temperatures you are seeing sound normal though ![]() ________________________________________ Rich |
allesclar
Seasoned Pro Location: Sheffield Registered: 17 May 2009 Posts: 4,254 Status: Offline |
agree with Rich E________________________________________ Team allesclar ® |
dented_vts
Regular Location: london Registered: 23 Feb 2010 Posts: 440 Status: Offline |
Rich E wrote: bluesixxer wrote: an easy one for everybody... recently acquired the car and was wondering if the temperatures it runs at are right, i believe the car has been stood a while altho it has a new radiator, fitted up on perchase... the range of water temps it runs at vary from 75c - motorway - all the way upto 95c in traffic (the traffic cleared at this point)... this seems quite a big range to me... oil sat at 90c, never moved... will fit a new thermastat regardless... one other thing, what temp shold i expect the fans to come in at?? any feedback much appreciated... watto 75 is too low. Our cars use an 83 degree thermostat so once warmed up the temperature shouldn't be below 80 really. I suspect you have a leaking thermostat, most likely due to the seal rotting. edit: The upper ranges of the temperatures you are seeing sound normal though ![]() Would the thermostat leaking like you say be enough to cause a noticeable drop in coolant? |
