Author Subject: Tappers!
garm
When i bought my car and all these threads i keep hearing about tapers.
What are they - what damage do they do?
I know it's to do with bent valve, but what causes this, why so prolific on 306s and what's the danger with tappers?
Cheers,
Pete.
Troubled Moonstone owner.
Posted 7th Jun 2010 at 16:57
poogiepug1
Its cause by a cambelt snap and if fixed incorrectly can cause the tapping sound.
The reason it happens on so many 306's is due to Peugeot recommending the cambelt change at approx 70k when in fact should be done at approx 45k, hence why so many snappers which if then fixed incorrectly causes the tapping.
I believe the tapping can also be caused from incorrectly fitting the cambelt
Im sure others will post on here soon and correct me if im wrong
Posted 7th Jun 2010 at 21:31
dickos
so if the belt is fitted wrong and it taps would getting the belt re fitted properly going to fix it? or is the damage already done,as thos maybe my problem
Posted 8th Jun 2010 at 01:37
damage already done! Doh
Posted 8th Jun 2010 at 01:43
cwspellowe
Damage won't be reversible, the tapping is a result of the valves making contact with each other due to poor cam timing. The valves bend, sometimes even the stems too, and the repeated closing of the ill fitting valves, and the kissing of two valves, makes the tapping noise.
Some tappers are ok to drive, just an irritating noise, but for the most part i'd say a few bent valves which will need replacing. Changing the cambelt will just mean it won't snap again any time soon LOL
Bye bye Sundance Kid Sad
Posted 8th Jun 2010 at 01:44
ryangti6
Dickos- If the belt is fitted incorrectly it will bend valves hence it will then tap, it will not be fixed by just refitting the belt correctly.
Garm- Poogiepug has pretty much answered your question other than the last bit, the danger with a tapper (as I found out) is that eventually the head of the valve will snap off the stem causing un-repairable damage to the engine.
Ryan
Posted 8th Jun 2010 at 01:47
jammamayhew Banned!
DONT BUY A TAPPER.....MINE LASTED 5 MONTHS Sad
Lesson learnt the hard way
JAMMA "M44YHW" MAYHEW
LOSE WEIGHT NOW - ASK ME HOW -
NUTRI-FIX
GTi6 LPG, The best of both worlds!
2006: 1997 R reg 306 1.4 Miami - Diablo Red - DEAD
2007: 1999 V reg 306 1.4 Meridian - Diablo Red - SOLD
2007-09: 1998 S reg 306 GTi6 - Diablo Red - DEAD
2009-10: 1998 R reg Corsa 1.2 - Blue - SOLD
2010-13: 2001 Y reg 306 GTi6 LPG - Diablo Red - DEAD
2013 - 2013: 2000 X reg GTi6 LPG - Moonstone Blue - DEAD
2013 - current: 2001 X reg GTi6 LPG - Diablo Red
]FOR SALE[/b]
"I LIVE FOR THE 306"
Posted 8th Jun 2010 at 01:53
dickos
damm guess i timed it wrong then lol
Posted 8th Jun 2010 at 02:01
ravemercer
How Obvious is this tapping ie just about hear it Loud or very loud as I'm looking to buy a 6 but due to insurance company's that pull my pants down with there quotes will be shopping at cheaper end of market.
Posted 14th Jul 2010 at 01:55
