Author Subject: Gti-6 Not starting after head swap
rob321
Hi.
My mates gti-6 managed to shear a cam pulley about two weeks ago. He bought a new head and put it on today, aswell as doing the gasket, water pump, timing belt, head bolts etc
The car fires up and will run with a lot of throttle but wont idle. With no throttle it will run then cut out after 1 second. He took the plugs out and said they look very rich. I doubt its a sensor because the car ran fine 2 weeks ago.
Any ideas why its not starting?
Posted 7th Jun 2010 at 02:05
ablister
did you replace inlet manifold gasket, could be leaking air into manifold?
306 rallye, Richard Longman engine
rc10gt
Posted 7th Jun 2010 at 03:06
crack in the plastic resonator is another quick check. had this on mine the other week
Posted 7th Jun 2010 at 03:26
mine did this after a head swap and turned out to be a damaged head meant no compression on no1 cylinder... just a thought but they also do this when the valves are bent Sad
first thing i would do is re check your belt timing ic correct as the bottom pully is very prone to de laminating causing incorrect bottom end timing. this could well be your problem if all sensors etc are plugged in. If timing is spot on i would do a compression test on all 4.
Posted 7th Jun 2010 at 05:18
