Author Subject: Using too much fuel / unused wiring plug?
pulsar_scott
Hi guys, been getting my phase 2 gti-6 ready for the road and took it for its MOT the other day. It failed on emissions so changed the lambda for an NTK one (as I had to grind the lambda out of the old cat which was rattling like a b*tch, so thought I may have damaged it). Put £30 of fuel in and took it for a blast, really giving it some for no more than about 15 miles. Guage now reads just above ¼ from around half before the blast.
Surely thats not right????
Also, in getting it ready for the MOT, I changed from a horrid rusty pipercross induction kit directly off the throttle body to a silicon elbow and ramair jobby. There is wiring connector not connected to anything sharing the loom with the plug fitted into the throttle body. Could this be the cause?
Any help or tips much appreciated peeps Smile
Scott.
Posted 6th Jun 2010 at 06:33
cress87
Firstly, the fuel gauges are often inaccurate so don't take the reading too seriously.
As for the connectors, there are a few un-used connectors on the loom so it's nothing to worry about.
Posted 6th Jun 2010 at 06:39
pulsar_scott
That makes me feel better thanks, but can they be a whole ¼ tank out? I previously had an almost 400BHP Pulsar that wouldnt use ¼ tank in 15 miles flat out Sad
On another note...... Whats the wee grey botton behind the ECU?
Posted 6th Jun 2010 at 07:00
wtf is a botton?
Posted 6th Jun 2010 at 15:51
Only "button" behind the ecu is the emergency fuel cut off switch and is usually red or black not grey.
Posted 6th Jun 2010 at 15:56
pulsar_scott
Please don't tease, it was late and I was tired Sad
Yeah I meant button, Thanks armzs16, it could be black yeah. Anyone else got any idea on the guage reading? Suely it cant be that innacurate?
Posted 6th Jun 2010 at 17:32
CUJ
Are all your sensors working properly as they could impact on fuel consumption.
340 horses
Posted 6th Jun 2010 at 17:34
pulsar_scott
Thats the thing, I dont know. The temp guage for both water and oil seem to working fine on the dash, warming up at an appropriate rate. How do I go about testing this?
Sorry for the 20 questions Sad
Posted 6th Jun 2010 at 17:38
your best off starting with a full tank of juice and seeing how many miles before the warning light comes on. typicly 300-400 depending on driving style and long or short runs.if its considerably less than this then the car is way over fueling which is usually caused by the green ecu coolant temp sensor on the thermostat housing or the lambda sensor.
Without a fault code reader i cant give you any more help than that.
Posted 7th Jun 2010 at 05:14
pulsar_scott
Thanks Armzs16, Ill do that and see what happens. Im guessing the ECU collant sensor isnt the temp sensor for the guage no?
Posted 7th Jun 2010 at 05:22
joevts
there are three sensors, one for the ECU/fuelling, one for the gauge, and one for the cooling fan switch i think. the one which would affect your fuel consumption is the green one i think.
Posted 9th Jun 2010 at 00:31
swiftyboi006
in 15 miles u can do a gallon mate i ran my car empty....put a gallon in....ragged it untill it was gone, 15miles i got. have also done the same driving as sensible as i can and got just over 36miles on a gallon
Black p3 Love
Posted 9th Jun 2010 at 22:25
