displaying posts 1 to 2 of 2
Author Subject: abs
dink
purchased a rear hub for the gti6 off sarah six and fitted it, cleaned abs sensor but now the abs warning light is on on the dash, will it go off when i move the pug and use the brakes ?
dink
Posted 4th Jun 2010 at 22:42
vincemasi
if you unpluged it then its normal that the light is on. once you start the engine and take it for a spin it should go off.
if it doesnt do a ECU reset.
if problem is still the then you must have damaged the senson and should replace it.
there is a guide somewhere on here on how to test the sensor to make sure its dead or good.
Posted 22nd Jun 2010 at 03:24
