Author Subject: adjustable top mounts
vts_tibi
Hi Guys,
I'm looking for a pair of adjustable top mounts for the Xsara VTS / GTI6.
I would like to mate these to the AST coilovers I have.
So far I know about AST, D2 Racing and K-Sport who makes adjustable top mounts for the GTI6.
The AST mounts are 250GBP Crazy K-Sport is 160GBP here in Hungary, but I don't know if I can fit them with the AST coilovers.
Here are how the K-Sport kit for the Xsara VTS looks like:
Do you think such top mount can fit over the AST shocks? As this is how my AST top looks like:
As I have no experience with pillowball top mounts at all could you please help me in this?
Cheers,
Tibi
VTS
best 60' : 2.272
Team Trackday™
Posted 31st May 2010 at 22:51
you would need a new top spring pan, unsure if the thread on the top of the piston rod is long enough for the Spherical joint either.
speak to Curtis Thumbs up (or ask Adam)
Posted 1st Jun 2010 at 00:04
vts_tibi
And where can I get such top spring pan? And how much are those?
I guess the piston rod is long enough, as it hangs out around 3-4cm from the original top mount.
I've asked Curtis, but the pair of AST mounts are 250GBP Shock
VTS
best 60' : 2.272
Team Trackday™
Posted 1st Jun 2010 at 00:07
mabgti
NV motors
have a search for my thread on here.. using compbrake items.
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 1st Jun 2010 at 00:13
vts_tibi
top mount thread
lurvely... this means K-Sport top mount would only fit if the AST and K-Sport springs has the same internal diameter
as at the top there's a flat surfaced thing, and I can not fit a spherical top hat (look at the pics. above and you'll understand)
VTS
best 60' : 2.272
Team Trackday™
Posted 4th Jun 2010 at 02:08
mabgti
NV motors
you can remove the bearing seat from the springs.. you need to measure the ID of the coil.. then choose a top hat to suit... comprake or spoox do the adjustable ones. K-sport ones look sweet but bit overkill on a 306 as the rears cant be much suited to much camber!
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 4th Jun 2010 at 01:25
vts_tibi
Yeah I know what you mean, but I would like to adjust the front suspension to give more negative camber
I know I can't do anything with the rear, but surely the bit more camber on the front could help.
To be honest it would be better to get more caster, as in a tighter left hander the right front tyre was rubbing on the sidewall!!!
But I don't think there's a topmount on the market which would allow caster adjustment....
VTS
best 60' : 2.272
Team Trackday™
Posted 4th Jun 2010 at 01:30
yes there is, BBM Smile
Posted 4th Jun 2010 at 01:43
vts_tibi
and where can I find them? Unsure
EDIT: I've found them here: Baker BM Clicky
but it's in "coming soon" status - do you know anything about these?
VTS
best 60' : 2.272
Team Trackday™
Posted 4th Jun 2010 at 02:07
best to email stew, website is due for update I believe, very helpful chap Thumbs up
I think 205 ones are in production, not sure if he has started the xsara/306 ones yet.
Posted 4th Jun 2010 at 02:15
vts_tibi
on the compbrake site I've found this:
CMB0303 - PEUGEOT 305 ADJUSTABLE TOP MOUNT
for the ultimate
in caster and camber
adjustment
surely... nobody makes an adjustable top mount for the 305???
VTS
best 60' : 2.272
Team Trackday™
Posted 4th Jun 2010 at 02:19
crf450
We do 306 top mounts I'll post some pics.
Quote "da g man!"
"You've only got to watch the "306 vs ringtaxi" video & you soon realise how good these mod's are! That guy is running Ash's 30mm ARB, Solid Mounts & 23mm Torsion Bars & some adjustments on the camber. Admittedly, the guy is an awesome driver, but it just go's to show how well these cars can handle with the right modification's
Posted 4th Jun 2010 at 02:20
pdd144c
I used Compbrake 205 items on mine.
FOR SALE
205 Turbo Technics complete and 306 Rallye Race Build breaking.
Posted 4th Jun 2010 at 02:22
crf450
These are ours.
Quote "da g man!"
Posted 4th Jun 2010 at 16:21
crf450 wrote:
These are ours.
Are these the same as Ash is using? And how much are they Martin?
Posted 4th Jun 2010 at 16:32
crf450
Yep same as Ash's,they are £250 for the pair and this includes top spring pans.
Quote "da g man!"
Posted 4th Jun 2010 at 18:04
puglover Banned!
do they require work to the bodyshell? look good those. Id be more interested in castor though i think.
Posted 4th Jun 2010 at 22:59
Drill some more holes rotate them through 90 degrees and hey presto, more castor. Smile
Posted 4th Jun 2010 at 23:01
crf450
I'm not 100% sure but I think every adjustable top mount I've seen (including the ones pictured in this thread) moves the strut down in the wrong direction even compared to where its sits as standard.
Ours dont do this, they move the strut up within a couple of mm of the bonnet so when you lower your car you dont loose suspension travel which is what will happen.
After I designed theses I was told that Peugeot had done the same thing on the works Maxi's by moving inner wing up to overcome the same problem .
They are only adjustable for camber but everyone I've sold them to has located them further back to increase caster.
You can achieve 4degrees of camber with them and they come with a template that locates in the original mount holds to guide you when modifying the inner wing when fitting them, this takes about 15 minutes a side with a angle grinder fitted with a narrow disc and file.
Quote "da g man!"
Posted 8th Jun 2010 at 18:40
rallyestyle
They look lovely Martin Love
Just Drive It
Posted 8th Jun 2010 at 18:51
cwspellowe
I like shiny things like these Love
Bye bye Sundance Kid Sad
Posted 8th Jun 2010 at 22:40
mabgti
NV motors
with my solid setup the rod sat at same height as oe Yes
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 9th Jun 2010 at 00:39
vittesse_tuning
has anyone here used the k-sport coilovers pictured?
custom carbonfibre and fibre glass parts. 07513059320
Posted 9th Jun 2010 at 21:34
oldbrownshoe
Thats exactly how the Indians lost Manhattan.
French military victories?
Did you mean French military defeats?
Posted 11th Jun 2010 at 02:38
