Author Subject: Compression question.
stainbox12
Anybody knows whats the compression between cylinders for xu7jp engine? My numbers were between 85-90 psi in all cylinders. Is that too low? or its ok. Thanks.
Posted 31st May 2010 at 07:04
oldbrownshoe
yes, very low.
the CR of this engine is 9.3 and the numbers should
be in the rang 150-200 PSI .
http://en.wikipedia.org/wiki/Compression_ratio
French military victories?
Did you mean French military defeats?
Posted 31st May 2010 at 11:52
stainbox12
hmmm ok... that might be then, the reason why the car wont start. I did a the comp test followed by dropping some oil into the cylinders, and the comp didnt raise up. What could it be? valve adjustment? timing? The head has been renewed.
Posted 31st May 2010 at 12:30
oldbrownshoe
read here:
http://www.custompistols.com/cars/articles/compression.htm
http://community.boxwrench.net/engine-rebuilding-forums/viewforum.php?f=9
Posted 31st May 2010 at 13:15
