Author Subject: Engine Swap Like 4 Like
infosellerfsmail
Just a quick one for you lads to put my mind at rest so i don't go mad!
Gotta 6 that has fully seized engine so i will be replacing with a 80k one.
Am i going to need the transponder and key or can i just do a straight swap and use the existing ecu, loom and key etc?
Its been a while your advice quickly would be appreciated.
Cheers Josh
Posted 29th May 2010 at 04:41
smighall
Smeg-all
Use all the existing electronics Yes
Meh
Posted 29th May 2010 at 06:26
dan@msx
old block out, new block in - as long as everything thats bolted to the old engine is transfered across then ya should be fine.
Transponder is part of the ECU and loom so as long as the original is used you dont have to worry about that side of things
Posted 31st May 2010 at 07:03
