Author Subject: Correct Pads? Pic Heavy
flexywozere
Hi all.
As a few of you may know i have a 106 GTI and have some GTI-6 calipers. As i bought just the calipers so was no real way to know which pads to have as there are several!
So i went to tweaks to buy some DS2500's and the guy test fitted these and said "these seem to fit", so want your advice really.
Pics:
Posted 26th May 2010 at 00:02
Rich E Forum Admin
Yep, they're fine as long as you're using GTi-6 discs. (Just posting the part number would have been enough, and searching for that number would have found you an answer too!).
The only watch out for the FCP565 pad shape is that it sweeps the entire surface of the standard disc and does not leave inner and outer lips like the standard pads do so you will need to use new discs if you haven't used that shape pad before.
Posted 26th May 2010 at 00:54
flexywozere
Haha thanks alot mate! Do the part numbers match up? Yeah ive heard about the disc situation...going to buy Brembo OE discs as theyre quite rated
Posted 26th May 2010 at 03:27
