Author Subject: Will these polish out??
kezman7
I think notDry
Probs by far not the worst thing ever seen but i was just impressed they have enought force to piece the piston like that, But then again i guess they were moving at 2000 rpm
Posted 25th May 2010 at 16:03
psjunkie
magic metal is your answer!Thumbs up
1997 P1 Gti 6 Charged
Posted 25th May 2010 at 16:17
fletch
Track Head
Tcut Yes
Posted 25th May 2010 at 16:57
kiwibrick
Those aren't bent(well they are but), these are bent,
Just pulled them out of my car.
The small grooves in the pistons are the standard valve reliefs, the valves didn't do that to the pistons
ph2 GTi-6
Posted 26th May 2010 at 03:16
kezman7
Jesus! How you do that!!
So they are i noticed today there also on the inlet side but the exhaust ones are now abit deeper than the others Lol
Posted 26th May 2010 at 03:17
Rich E Forum Admin
^^ That's the usual damage that results from cambelt failure Yes
Posted 26th May 2010 at 03:47
kezman7
Aww im kinda disapointed mine only slipped now, would have loved a set of them beautys to keep!
Posted 26th May 2010 at 03:48
kiwibrick
Yep stripped sbout a dozen teeth off the belt, and was doing just under 2000 revs, bent all the exhausts and 4 of the inlets but I replaced the lot, just going to finish putting it back together tomorrow actually.
Not sure what to do make with my set of 8 bent exh valves yet though LOL
ph2 GTi-6
Posted 26th May 2010 at 15:13
Have you done anything about your valve guides? That kind of damage will have almost certainly made them go oval.
Posted 26th May 2010 at 15:25
kiwibrick
Valve guides are fine thankfully, not even a hint of any damage.
ph2 GTi-6
Posted 26th May 2010 at 16:19
