Author Subject: battery to starter wire?
bobdylan_55
Hi, i was reading the guide on battery relocation and people were saying 25mm^2 wire should be used minimum etc.
However ive done some calcs, and based upon the gti6 starter being 1.1kW then a rough figure of 95amps can be found.
So surely 16mm^2 110amp wire would be plenty good enough?
cheers
309 GTi6-T
Posted 24th May 2010 at 22:53
mr swampy s16
**BAD SELLER**
better to over spec than under spec
i have 4 metres f 135amp battery cable for sale
Posted 25th May 2010 at 00:50
For mains cable we use at work, 16mm2 is good for 63A and 35mm2 is good for 125A so 25mm2 for 95A looks about right.
Posted 25th May 2010 at 04:40
bobdylan_55
mains is different though, ac is not the same as dc
309 GTi6-T
Posted 25th May 2010 at 16:24
