displaying posts 101 to 125 of 775
Pages (31): first .. 4 [5] 6 .. last
Author Subject: Track Cars for Dummies
Post #101
Dunno what you mean, that has nothing at all to do with my eating rice for the next three years.
Posted 8th Jun 2010 at 00:27
farmer
Post #102
dangerous dave wrote:
love the commitment.
Joney from here had the same coilovers I think, however he got them professionally set up somewhere near the Essex region. I think it cost him about £250 but the car was just insane afterwards, sub 9 minute ring lappery with only 130bhp. Definately needs a baffled sump though.
No Joney definately didn't have KW's No
I nearly bought that car, but changed my mind after deciding I CBA with the time to 6'iyfy it.
Sure that car had Gaz or something else like that tbh.
Ask Gary! Wizard
Long live the Sigma 6 Big grin
Team Phase 1 supercharged
XBL ID: farmer uk1
Posted 8th Jun 2010 at 02:40
farmer
Post #103
owain wrote:
Cheers Rikky that's worth knowing, I've actually got a battery powered one but didn't think it'd be up to it. As I don't need them off right now I'll leave it til after Oulton Park next week in case I break anything, then I'll have a bash.
Thanks muchly!
Oh, forgot to mention, I have a compressor and impact wrench here too Whistle
Its not very good though tbh.
XBL ID: farmer uk1
Posted 8th Jun 2010 at 02:41
Post #104
joneys had avo's set up by pete farmer
Posted 8th Jun 2010 at 05:02
Post #105
Cheers again Farmer, might be heading over your way in a couple of weeks if I have no luck then!
Posted 8th Jun 2010 at 11:34
farmer
Post #106
Give that man a benaner!
XBL ID: farmer uk1
Posted 9th Jun 2010 at 06:21
n.g.k
Post #107
Craicing thread! Laugh
Well wear with it bud!
Inside you are face!
Tune Of The Month
Posted 9th Jun 2010 at 08:00
Post #108
Just a quick little update, as I've been having some more fun today. Last night I got my car back from the workshop, where they've done a cracking job of welding up the sunroof. They plated over the top rather than dropping a plate into the hole firstly as they were concerned about how much the roof would distort with the welding, but mainly because I didn't want it filling up with water.
Still, few kilos saved and some all-important headroom saved.
Annoyingly they only primered up half, so I've sanded that back and I'm just going to spraycan the roof to make it finished enough. Not going to bother making it look too good any time soon.
Next I fitted the Viper air filter I'd bought. For this, you need to start by throwing away the useless instructions that come with it and just use some common sense - the old airbox unbolts from under the passenger wing:
This bit comes off with a torx bolt, try not to spill your coffee:
Then dick around for ages with a ton of cable ties until everything's held securely enough in place. At some point I'll neaten it up, but it's too hot out there to be worrying about silly little things like that.
Irritatingly, despite what the "oh hell yeah, this one's made JUST for the 306" marketing would have you believe, there's no room for the filter and there's nowhere for the engine breather pipe to go. You'll need to cut up the hose that comes with it to give yourself a 90 degree angle down, then fit the filter down a little.
Luckily Halfords sold the little breather filters - I paid the £2 extra for the Pipercross one so I didn't have to stab myself in the face as punishment for buying the Ripspeed.
Cost 4, Difficulty 2 and Time 1. BS of 8.
Clutch Cable - I'd bought one a little while ago but hadn't gotten around to fitting it yet. For once, it seems like the Car Gods (whom you might remember from such mentions as the one by the ever-talented Michelle Rodriguez in the epically-accurate Fast and the Furious movie) were on my side. Apparently this task is normally dogged by the air con pipes being in the way and needing to be loosened off in various places.
No air con, get in.
Not really worth having any pictures but basically disconnect the gearbox end to give yourself some slack and remove the white clip from the pedal. Tie some string to the white clip and pull the old cable through the bulkhead into the engine bay. Untie string, tie new cable and pull it back through. It'd a fiddly one and a job that'd be much easier if you had a friend the other side of the bulkhead to push or pull; unfortunately I work in IT and so therefore have no friends.
However, probably half an hour all in. Cost 1, Difficulty 3, Time 1. BS of 3 on a non-air con car.
I then bit the bullet as I'd run out of other jobs to do other than try and get those bastid torsion bars out. Long story short, it's not happening. Slide hammer no, probably because the only attachment I have that was half suitable was a set of mole grips which just kept slipping off. A socket, some washers and some M8 threaded rod also no, rod just snapped. So after some time I gave that one up, alas it's going to have to go to a garage to get those off - 140,000 miles seems to have taken its toll. Very annoying, but I'm only going to damage something if I carry on any more.
Until next time...
Posted 9th Jun 2010 at 21:55
cwspellowe
Post #109
My clutch cable replacing consisted of it snapping 100yards down the street, fitting a replacement, driving to Blackpool, cable snapping again because the grommet in the bulkhead wasn't sitting right and the cable frayed on the bare metal, having to borrow my Dad's car to get back to Glasgow to work that night, leaving my Dad to fit the new cable and driving to Gretna to swap cars back 2 days later.
Including petrol costs and temp insurance costs.. calculate the BS value of that Dry
Bye bye Sundance Kid Sad
Posted 9th Jun 2010 at 22:22
Post #110
Heh, sounds a hoot Wink
I'll look forward to mine snapping shortly then, thanks for putting that idea into my head.
Posted 10th Jun 2010 at 00:12
Post #111
Right, update time. Having given up on doing my rear suspension any time soon, it's time to start getting the car ready for Oulton Park on Tuesday. First issue is the blowers, a cable to which I forgot to put back last time. Dash out, find wire, replace.
The scale of how much easier it was to remove the dash this time around really does go to show quite how many nuts and bolts didn't get put back last time. Is this a concern? Na, it's weight saving.
So, blowers working and it's time to replace the matrix pipe of death which I broke last time. If you've never broken your matrix pipe trying to remove it, you will. It's this little bugger:
Bear in mind your coolant system is (hopefully) all full of coolant, so it's important to carefully drain the system first. I do this by yanking the pipe from the block, the old coolant will soon drain itself with the help of gravity and a gravel driveway.
Remove metal clips from the ends into the block, replace with new hose, refit. Simple.
To refill, you'll need a reservoir higher than the cooling system to make sure you're rid of any bubbles. That'll do nicely thankyou:
Turn the engine on so the water pump starts going and just keep pouring in coolant until it stops going down. Then unscrew the bleed screw on the new plugs you just put into the back of the matrix and this little one on top of the rad:
Close them when they start p*ssing coolant. Fill up the header tank until it's about full enough but not too full but full enough but not too full.
You'll find it easier to close the bonnet if you remove the coke bottle and replace the header cap.
Next job - gotta be the throttle cable. Now, there are two ways of doing this - the simple quick way which just involves replacing the inner metal part, and the proper way which involves replacing the whole thing.
If you've never done this before, you'll be just like me. You'll think that if a job's worth doing it's worth doing well, and you might as well replace the outer.
Take one look at where the cable goes into the bulkhead, realise the brake master cylinder and servo are in the way, and decide to just do the inner. Remove the little securing nut from the metal thing with the hole in it on the throttle:
You'll then be able to remove this clip from the top of the throttle pedal:
And just pull the inner through from the outside. I then poured some 3-in-1 oil down the sheathing and clipped the loose end up to the bonnet to let it run down - the inner didn't actually look to bad so I assume it's the outer sheath that's knackered. Push the new cable through from the pedal end, clip back to pedal and refit to throttle.
I replaced the little clippy thing with my new one, just cos it was shiny:
Cost 1, Difficulty 1, Time 1. Can't get better than that. A noticeable improvement but still a little sticky at points, so probably worth doing the outer at some point.
Right, I've got a big ol' drive up to Oulton on Tuesday. I now have air and heat, but no stereo. Even if I did, I have no speakers. I'm sure as hell not fitting any, so we'll have to come up with something else.
CHECK OUT MY PIMPIN ICE, b*tch.
Hell yeah that's the CD player with iPod dock outta my kitchen. And oh yeah we've pimped it Big Dog Stylee, with some phat wires from it going to an old phone charger I found, which turned out to be a 6 volt one so I had to solder up its innards, hell yeah.
Spade connectors for the win.
Won't catch me wit no tunage.
Ah crap, I've only got one cigarette lighter socket. I'm going to need sat nav, bluetooth phone thing, b*tchin ICE, and phone charger. That's not gonna work. Luckily, Maplin sell those little splitter things.
Unluckily, I'm an idiot.
Get an old painting tray, namely the one you used to do the lounge - you never bothered cleaning it because you couldn't be arsed, and now it's ruined.
Cut out a rectangle 192x67mm, roughly (I think, don't quote me). This is simpler done with a good Stanley knife, albeit at the serious risk of losing a finger.
Once you've done that, drill out three holes for chassis-mounting 12v sockets from Maplin.
You'll then need some kind of plastic or metal to make some mounting lugs. This looks like it was important, but the fact it's no longer attached to the car means it's probably not:
Cut yourself a couple of little bits like so:
Drill a 4mm hole in one side, and a pilot hole for some self-tappers in the other side. Then, fit them on the studs that hold the centre dash in and fit the 8mm nuts behind:
Now, we need power from somewhere; let's nab some from the current cigarette socket. I only have 2.5mm cable which isn't that big in car terms, so I'll run two in parallel. Power feeeeeeeeed:
And connect up the sockets:
Won't catch me running out of power.
I think that's pretty much me done for now, I'm off to break something at Oulton Park.
Posted 16th Jun 2010 at 18:46
Post #112
Quality Big grin
Posted 15th Jun 2010 at 00:04
Post #113
that throttle cable would have been replaced sometime in the past if it already had that pinch bolt arrangement on it, in which case I'd probably go to the trouble of fitting the outer as well as the inner, seeing as you've bought it already Smile
Posted 15th Jun 2010 at 00:11
Post #114
I might have done if I could've seen how it was attached, but other than yanking something and risking breaking it I couldn't see any way of removing the bit through the bulkhead.
Unless of course you'd care to explain... Wink
Posted 15th Jun 2010 at 00:50
berger
Post #115
Theres a bleed screw on the housing with all the sensors (green, blue and brown) on the side of the block too iirc?
Bang'in 7 gram rocks!
I have one gear, GO!
Posted 15th Jun 2010 at 01:31
Post #116
I hope you're not implying that there's a need to be thorough? Wink
I shall keep an eye out, cheers.
Posted 15th Jun 2010 at 02:00
smighall
Smeg-all
Post #117
Which also snaps fairly easily, so be gentle!
Meh
Posted 15th Jun 2010 at 03:05
rallyestyle
Post #118
LOL Love the power option Thumbs up
Just Drive It
Posted 15th Jun 2010 at 17:43
Post #119
5mm allen key, just needs to come slightly out as its drilled. Always scared the crap out of me undoing that one...
So how much weight has the new 12v system added then. You're going to need a massive alternator or a generator in the boot before long Razz
Posted 15th Jun 2010 at 17:53
cwspellowe
Post #120
owain wrote:
You'll then be able to remove this clip from the top of the brake pedal:
I certainly hope that wasn't attached to the brake pedal Blink
Posted 15th Jun 2010 at 23:35
Post #121
Hey, it's easier than heel & toe Wink
Posted 16th Jun 2010 at 18:45
berger
Post #122
Did the throttle cable make much difference?
The throttle on mine seems to occasionally stick, the revs slightly increase when pootling around in traffic when you lift off the throttle for a split second before dying down.
Figured its worth a change if they are only cheap?
Posted 16th Jun 2010 at 19:26
Post #123
To be honest changing the inner has made a difference, but it's still sticking a lot. The throttle butterfly turns really smoothly by hand and the pedal was free and smooth with the cable off, so it can only the outer sheath.
Assuming I can figure out how the outer sheath comes off it'll definitely be worthwhile, else I probably wouldn't bother.
Posted 16th Jun 2010 at 20:14
dhampton
Post #124
I've noticed the throttle cable is routed differently on some cars. The ph1 and older ph2 cars have been round the front like this:
Later ph2 and ph3 like this:
I assume they did this because of an issue?
Clio 182 FF 306 Rallye (track) 306 Gti-6 Megane R26 Clio 172 Cup (track) 106 Rallye S2 (track) 306 Rallye Saxo VTR 106 Zest2
Posted 16th Jun 2010 at 20:27
Post #125
Certainly the newer way of doing it doesn't involve doubling back on itself just before the throttle, so I'd assume it was because of that.
