Author Subject: S/C'd help:-Have i cocked up?
simonjames
Basically i'm putting the car back together and dont remember removing the engine from chris's old 6 mainly cos of all the pain killers i was taking at the time, below is a pic of my engine sat in my bay, today i set about fitting the pas resivour and pipe work and have discovered in the switch over i've only got a small bit of pipe from the pas pump this should go under the engine to the rack i noticed that on a standard 6/rallye pas setup the pressure switch is right by where the end of my pipe is, so does the end of my pipe connect to the original switch housing or am i missing part of the re location kit?
MY EBAY ITEMS
07943066306
Posted 18th May 2010 at 02:52
no idea but painkillers are nice arnet they?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 18th May 2010 at 03:00
simonjames
lol yeah i seem to have memory loss though big chucks missing, i dont remember removing the engine but apparently i did
MY EBAY ITEMS
07943066306
Posted 18th May 2010 at 03:10
rallyestyle
Is all the standard pipework still in place that takes the PAS fluid from the pump to the rack? It goes across the front and then around the back, it will be snipped on the front and thats where you new piece of high pressure hose connects just before the sensor.
Just Drive It
Posted 18th May 2010 at 03:28
simonjames
no its not there but i do have a few spare engines out the back im sure there would be a spare pipe i could rob off 1
thanks mate
MY EBAY ITEMS
07943066306
Posted 18th May 2010 at 04:13
simonjames
robbed a pipe off a spare engine today, am i right in saying i need to cut the std pipe and take it to someone with a crimper to srimp on a hydraulic end ?
MY EBAY ITEMS
07943066306
Posted 18th May 2010 at 20:37
rallyestyle
No
You see that fresh bit of pipe you have coming off your power steering pump going across the front of the engine in the pic above, that has compression fittings on both ends that clamp to the piece of pipe where you cut it as required and seal as needed. However if the fitting has already been fitted i think you will need a new olive for the inside otherwise it wont seal properly. Rich should be able to tell you what bit is required.
Just Drive It
Posted 18th May 2010 at 20:55
farmer
Just make sure when you cut the pipe before the PAS switch you leave about 1" of solid pipe for the compression fitting to sit on.
I have the entire original s/c fitment guide somewhere in .pdf if you want me to e-mail that to you?
If you do, drop me a PM with your e-mail address.
Long live the Sigma 6 Big grin
Team Phase 1 supercharged
XBL ID: farmer uk1
Posted 18th May 2010 at 21:23
simonjames
that would be really handy mate if you could simon@swfco.net
the set up must have been there on chris's 6 but f*ck knows where ive put it if i've taken it off the car
MY EBAY ITEMS
07943066306
Posted 18th May 2010 at 21:31
birk
Is that boost pipe from the charger a good silicone one ? it will collapse when on idle, if it was me, i'd get it hard piped whilst you have the front end off.
Dimma + Gt35 turbo = Ninja
Solid rear beam mounts £130
07889376885
Dan
Posted 19th May 2010 at 00:53
simonjames
its hard pipe most of the way inside the silicone, im going to see what is like but i may end up doing it all in hard with just the straights under the slam panel to take the engine flex
MY EBAY ITEMS
07943066306
Posted 19th May 2010 at 04:11
smegal
The fitting instructions as well if you need them
Ex SC-6
Now in a Megane R26
Posted 19th May 2010 at 04:27
simonjames
Posted 19th May 2010 at 04:35
farmer
Sorry I never got round to sending them to you mate, totally forgot about this thread Blush
Atleast you have them now though!
XBL ID: farmer uk1
Posted 22nd May 2010 at 03:52
simonjames
yeah all sorted now ordered the olive and comp joint from rich
MY EBAY ITEMS
07943066306
Posted 22nd May 2010 at 04:41
