Author Subject: Fuel Leak (above cam cover)...
lwgti-6
Afternoon guys,
Just a quick question,
Fired the car up this morning, ran for a few seconds then cut out. Turned the key again, did the same, my thoughts were fuel starvation...
Had a quick look around the fuel line area, nothing leaked on the floor so i popped the bonnet and had a quick nosey to find the 2 fuel pipes which go into the fuel rail seem to be leaking slightly...Probably down to wear?
Now my question is can i use any pipe within 15mm diamiter or is the pipe some sort of special high pressure piping? Also when i take the pipes off to replace them, will petrol p*ss out everywhere as its under pressure?
EX Bianca 6 owner,
Now drives: Octavia vRS
Posted 15th May 2010 at 18:13
Rich E Forum Admin
You'll get a little fuel seepage, yes. You can minimise this by cutting the fuel pump power with the engine running and letting it stall.
You need to use proper fuel hose though. One is 8mm ID and the other is 10mm ID. It's a good idea to do the ones that come up from under the car too. They are both 8mm ID.
Posted 15th May 2010 at 18:25
lwgti-6
Thanks mate, appreciated!...
Allthough it was a little more than seepage, Never had any before.
Ah well, shall be ordering some pipe now.
EX Bianca 6 owner,
Posted 15th May 2010 at 18:28
ann306
Hello Rich I want to change all my fuel lines cause i think they are wearing out could you please tell me which colour the 8mm is on and the 10mm please for the fuel lines by the cam cover and also the ones coming up from the car please
Posted 21st May 2010 at 04:11
lwgti-6
The 10mm is the pipe above the smallest one which is the 8mm...
EX Bianca 6 owner,
Posted 21st May 2010 at 04:12
