Author Subject: Difference between rear beams
devere
Hi, I expect i will be told this has been covered before, but im in a real hurry with this.
Is there any difference between the disc rear beams. Meaning, is the GTi6 disc beam any different to other rear disc beams...?
Like i said, im in a hurry so couldnt search too much. Need to get another one asap and there is a disc beam for sale real local.
Cheers.
Posted 13th May 2010 at 23:30
as long as it comes off an XSI or a DTurbo HDI then it'll be the exactly same, but on a rally car it shouldn't matter as you'd be fitting uprated torsion bars regardless of what it had originally.
Posted 14th May 2010 at 00:13
devere
Cheers for that. Was just wanting to check that the actual beam itself was the same. Having to pick one up quick. Sad
Posted 14th May 2010 at 01:11
simonjames
Also xsara beams also fit
MY EBAY ITEMS
07943066306
Posted 14th May 2010 at 01:21
yeah, any Disc brake ZX Xsara or 306 beam should suffice, the geometry of them does vary a little but they are essentially identical.
Posted 14th May 2010 at 01:54
