Author Subject: B1 GEARBOX
tannerman
has anyone used a B1 in thr gti6...bin offered 1 cheap and trying to find out if ill benifit from it in anyway.
cheers folks
DO YOU HAVE PROBLEMS WITH BUM FLUFF
Posted 12th May 2010 at 16:45
tannerman
the B1 is the 5 speed. its got a short 1st 2nd 3rd with a long 4th and 5th bin told the acceleration is ALOT better and top end will b good for over 140mph. the box i brought comes with a quife atb diff. the only problem is you have to chop n change reverse gear.
just need to no if its as good as they say.......
any1 got 1????
Posted 12th May 2010 at 17:45
miles
What a load of *******, A BE1 gearbox is no better or worse than any other, the Ratio's you have been told again is rubbish as 3 & 4 share the same gear cluster unless a C/R box,
It sounds like a 205 1.6 GTi maybe with a Mi16 5th which will be a huge jump,
Top speed won;t be anywhere near that if it's good on Acceleration
www.pugracing.com
Posted 13th May 2010 at 03:01
tannerman
this is all stuff iv been told so i wouldnt have a clue
Posted 13th May 2010 at 03:24
tannerman
i think it is a custom box as my mate owned it previous...chers for the help tho
Posted 13th May 2010 at 03:25
tannerman
would u suggest i keep the 6speed thn???n just put the diff in thr??
Posted 13th May 2010 at 13:56
miles
I would,
But depending on use the 1.6 or 1.9 box with a 4.4 CWP gives a cheap upgrade for track work, not much use on the road thou
I'd be rich if everytime I;ve been told it's a .... was true
www.pugracing.com
Posted 14th May 2010 at 03:13
tannerman
KK mate thank you for the advice.are ther ever any meets around the ringwood area....i live in ferndown
Posted 14th May 2010 at 12:55
miles wrote:
I would,
Got a box like that kicking around Miles?
Posted 14th May 2010 at 14:13
daveyboy wrote:
miles wrote:
I would,
Unless you've got a raised rev limit i'd stick with a xsara 5 speed personally, using the xsara rack and PAS ram. You'll run out revs and its a pain in the arse on the road. The xsara box is a tad lighter and a tad stronger than the 6 box.
Posted 14th May 2010 at 15:08
miles
Can have in a couple of weeks,
Just done a 4.8 CWP with a 1.9 gearset, 95mph at 6000 rpm, LOL
www.pugracing.com
Posted 14th May 2010 at 19:38
