Author Subject: PeterT stage 2 cam on standard management?
karoshi
Has anyone run one on standard management?
Peter reckons it should idle fine but the mechanic and I are having trouble...
Going through all the regular things but not having any luck.
Engine was honed and re ringed and the head reco'd with stage 2? ( 226 deg. Duration, 0.0350" lift) with stage 1 exhaust cam( 215 duration , 0.0400" lift????)
Heard the same cam combo in an mi16 and idled fine on standard/chipped management.
Different animal though....
Appreciate any input. Thanks in advance.
Bill
Bill
Posted 5th May 2010 at 14:26
dannyb1
Im not farmiliar with the standard duration , but if these have a fair bit more duration you may need to fiddle with the pullies to sort the timing out.
You want tact ? Call a tactician !
Xbox 360 : Cableguy1984
Posted 5th May 2010 at 14:42
karoshi
Sorry forgot to mention that.
Timing set at design advance.
Mechanic was pretty nervous advancing it a much as Peter had advised but we are certainly in the ballpark as it runs pretty darn well except at idle.
Bill
Posted 5th May 2010 at 15:23
karoshi
Any other ideas?
All appreciated.
Bill
Posted 6th May 2010 at 02:43
I thought he says on his site that it won't run with standard management...? Even the stage 1 inlet cam! Thats why I went the V6 route rather than sort my blown engine and drop one of his cams in.
Posted 6th May 2010 at 02:59
karoshi
Stage 1 runs but majority of the data on the website relates to xu9j4s.
Mmmm v6
Bill
Posted 6th May 2010 at 08:32
vts_tibi
Mmmm v6
I have a stg.1 inlet cam and I had to buy a standalone ECU, as with the original ECU the idle was stable, although the ICV wasn't able to cope with the modification, so whenever I slowed down before a junction it stalled.
And as nobody could remap the original ECU here I had to buy a standalone ECU.
Ohh... and the power difference is even more immense with a remap Cool
VTS
best 60' : 2.272
Team Trackday™
Posted 6th May 2010 at 12:47
karoshi
quote:
You have just stated my exact symptoms thank you.
I am really looking for excuses to go aftermarket ECU. I think that's broken the camels back though.
Start approaching installers tommorow!
Thanks all
Big grin
Bill
Posted 6th May 2010 at 14:04
karoshi
Update. Idle issues solved.
Stepper motor the culprit.
Bill
Posted 17th Jul 2012 at 11:32
