Author Subject: Engine not feeling right
davsin
I thought that the engine wasn't running very smoothly today, no tapping noises but it fells like it is struggling or tight, its idling at 1000rpm and seems to chugg rather than purr. It has a K+N filter on it but no cold air feel but at stand still its not right.
Anyone any ideas on how to sort this?
renault 5 campus sold
sierra sapphire cosworth sold
Peugeot 1.6 xs sold and gone to car heaven
Audi S2 220hp sold
Audi S2 Modified 295hp sold
Audi A3 Quattro Sport 180hp Sold
Peugeot Dturbo Sold
Volkswagon Passat 4motion V6 Modified 230hp SOLD Peugoet 306 GTI 6 FOR SALE
Vauxhall Signum 1.9CDTI 189bhp (chipped)
Posted 30th Apr 2010 at 03:40
cwspellowe
Idle control valve
MAP sensor
lambda
Give them a clean as a starting point, there's an FAQ for the sensors on this site Thumbs up
Bye bye Sundance Kid Sad
Posted 30th Apr 2010 at 03:42
darkgti6
Your K&N is pulling in a lot of hot air at stand still that might be causing some problems. General belief on here is that the only induction kits worth having are the sealed type with air feed!
Other than that if its not running right try giving it a good serviceUnsure when was the last timne it was done?
Team Peugeot Sport 308 Gti�
Posted 30th Apr 2010 at 03:44
kit
Lumpy idle is most likely down to the idle control valve (stepper motor). Clean it with carb cleaner and see if that helps.
Racing driver, fighter pilot, astronaut, compulsive liar.
Posted 30th Apr 2010 at 03:46
davsin
just a thought but there is a black rubber pipe at the rear of the inlet manifold that the previous owner(s) has put in to the side of the K+N filter and if you cover the end of the pipe the cars engine stalls, idle control pipe maybe?
how do i finish this pipe being that its not meant to be like that?
Audi S2 220hp sold
Peugeot Dturbo Sold
Posted 30th Apr 2010 at 03:49
kit
Sounds to me like the previous owner didn't install the K&N correctly Doh
The ICV is located below the MAP. Is that the pipe you are on about?
Posted 30th Apr 2010 at 03:53
cooper666
sounds like the icv pipe has broken away from main air intake pipe
clio r27
ps3 id:cooperkloe
aaron6
If its the breathes pipe for the idle broken off, it wont like it much. Just whack a small air filter on the end and blank the hole in the main filter pipe with tape. Smile
Posted 30th Apr 2010 at 17:17
davsin
Better if i take a pic to show you after the weekend
Audi S2 220hp sold
Peugeot Dturbo Sold
Posted 30th Apr 2010 at 21:55
davsin
Clutch is slipping in 1st gear
The problem below is the idle control pipe
davsin has attached the following image:
Audi S2 220hp sold
Peugeot Dturbo Sold
Posted 6th May 2010 at 06:12
smighall
Smeg-all
Bodge tastic! Clapping
Meh
Posted 6th May 2010 at 06:58
davsin
did the clutch myself and the steering rack, Passed the Mot with no advises!!
Audi S2 220hp sold
Peugeot Dturbo Sold
Posted 8th May 2010 at 18:07
