Author Subject: Universal Lambda Sensor
cescnathan
Hello, my gti6's lambda seems malfunction due to heavy fuel consumption, exhaust popping and idle running not stable.
Does anyone try the Bosch Universal Lambda?
Any difference between the Bosch direct fit and universal one?
Posted 26th Apr 2010 at 07:36
Only difference I can think of is that the direct fit will work, whereas i've no idea on the other one.
Posted 26th Apr 2010 at 15:55
stegti6luvr2
have you had it on diagnostics?
Posted 26th Apr 2010 at 16:05
cescnathan
yes mate, error code showed map & lambda sensor are malfunction, i'd replaced the map, wished map effected the ECU only, after engine warms up, popping and idle problem happen again.
it seems lambda need to be replaced too.
Posted 26th Apr 2010 at 16:16
cescnathan
Posted 26th Apr 2010 at 16:20
Rich E Forum Admin
A 4 wire universal one will be fine. Universal sensors come with bare wires and you have to cut the connector off your old one and join them together.
Posted 27th Apr 2010 at 02:32
cescnathan
thanks mate! i will try the universal one.
Posted 27th Apr 2010 at 07:23
